Replace android with ics.
Just installed ICS after not using Cynagenmod since the first Alpha, also had to fix that since WebOS had updated since. Bit of headscratching but it was quite straightforward with the help of a youtube video.
First impressions of ICS is it's very swish looking, and the stock browser is a big improvement, it seems very smooth at the moment, will be happy when they get YouTube HD playback working.
Does anyone know of an idiots guide to installing ics onto a stock touchpad?
Finally decided to make the jump.
Would highly recommend ICS Bricked Rom!
No CM7 isn't. CM9 is ICS.Robb, can't i just go straight into cm9 or do i have to install cm7 alpha first?
I have the folder all good to go.
Edit ahh cm7 alpha 3.5 is ics doh lol.
Never mind i had a brain fart.
