[TW]Taggart;21207478 said:exactly, the mclaren was the faster car at the end of 2011 so low nose vs High nose is clearly not a problem
How did the McLaren do at Silverstone with no EDB....
I'd put money on it but I know full well you'd not cough up come the end of the season![]()
So you really do know it all then, figures
we shall see won't we.
We shall see![]()
Put it this way.
If the high nose is such the advantage you perceive it to be we would have noticed it more so last year. The noses last year were ran even higher.
If McLaren felt they were losing out in this area they would have adapted over the winter. I'll repeat myself, a high nose is not a bolt on go faster part like the F-duct was.
High nose will negate the loss of EBD somewhat, McLaren have not yet recovered that loss, others are said to have done so already.
You guys are all wrong, the stepped nose is the way forward.
So you really do know it all then, figures![]()
The redbull splitter looks like a snow plough to me, as does most other car's splitter
The Red bull doesnt have a snowplough at all.
This is the snowplough-
http://scarbsf1.files.wordpress.com/2012/02/mp4-27_front203-4.jpg
Mclaren are the only team to run it and have done for several years, their design concept for several seasons now has been about having a good, low front end as oppose to sacrificing all and everything to gain a bit more aero.
A higher front nose while gaining a bit more air underneath compromises front suspension geometry, CoG and driver visibility, if the snowplough is doing the job (mclarens have had good front ends for a while so I presume it is) then why should mclaren throw away years of development just to fit a different type of compromise when what they have works pretty well as is.
As for lasts years cars dodgy backend, it was designed for a very fancy exhaust system whose materials were banned by the FIA at short notice which was a day 1 abortion leaving mclaren no option but to scrap the back end and possibly cost left them months behind in rear end development.
The only thing that bothers me with the Mclaren is the exhaust-wart placement.
You'd think they'd blend it in to the sidepod a bit, at the moment it's just terrible.
The rear designed for the octopus exhaust compromised them for the whole season. Not only did they not get any proper test mileage with the configuration that was raced, but the gearbox was raised to allow the exhaust to fit under it, compromising the CofG and then they never gained the benefit of the correct exhaust.
