I've got a feeling they fit it with the fans up top and the rad inside, I asked in the CS section and was told that the EX240 fits... I just don't see how without it being stupendously tight to fit things around it!
Looking at your build log I would guess thats the case, you appear to have at least another 10-15mm between the fan and the memory, I guess what space is available may be motherboard dependant.
Very nice build by the way Cyanide
I wonder if they mount the radiator on the underside and have fans on top under the mesh? As according to corsair there is only 29mm clearance under the mesh side and the EX240 is 35.5mm...
@iTek what about the V8 kit? http://www.overclockers.co.uk/showproduct.php?prodid=WC-041-OE&groupid=962&catid=1532&subcat=
Provided that EX240 does fit on one way or another as mentioned above that has pretty much everything you are going to need.
I'm potentially going to go for this so we shall know shortly, would you have the funs pulling on the top or pushing...
It might not be the EX then (although this is what they told me), I looked on the XSPC site and it said it was like 27mm thick.
What was 27mm thick?
I would have thought they'd put it in the top of the case (where I've got the fans on my build) rather than the top grill section as there's no way it'll fit under the grill.
*edit* My Magicool slim barely fits in there without distorting the grill so I'll eat my own face if you can fit the EX240 in that bit witout modding sometihng
But where specifically in the top of the case? Seems a bit aof a vague reply. I'll measure mine tonight, near positive it wont take a 35mm Rad (ex240).
