Corsair 500R Watercooling options?
What size rad and what are you planning on cutting?
Edit: and congrats on the new gpu :D another 6950/70?
Just a 240mm but in the front, the area which needs cutting is a little section from the bottom 5.25 drive bay.
Yes same but different card :p
Would like to thank Cupra for is skills on the Dremel, a few shattered discs later we got the radiator in place. Everything else was easy except a small leak which sprung out, school boy error.
Temperatures are pretty good indeed, GPU just been through Heaven at 40 Degrees C, in comparison to on air it would hit 78 degrees so a massive reduction. The cpu temperatures have dropped a further 1 or 2 degrees, obviously had to re-apply thermal paste, air bubble etc so could even be better, not sure what the cure time is on MX4 if any?
Really happy. That is all!
Looks really good! Especially as all of the tubing heads back to that top rear quater, just makes it look tidy :D
Did you hit any other issues installing the front rad other than the obstructing 5.25 bay?
you dont even need to dremel it, just contact pulse modding about making you a window ready to go in
I quite like the side fan though.
Ran some Furmark this morning for a hour or so and card never went above 45 degrees. That's with at clock speeds 950/1375Mhz
1080 Score
