We are a bit worried on the mobile front, the 670M might just be a rebrand of the 570M and the 675M and 680M (which cost more than the 580M does now) are going to be the new chips.
Won't be the first time Nvidia done this.
Partners got the briefing
We got word that Nvidia finally talked to its partners about its highly confidential Kepler products.
They got briefed, they got the reference design and the production of the cards is staring as we speak. It looks like most of the cards available at launch are going to look alike, with different cooling from some partners, but the non-reference partner cards will come a bit later.
Nvidia should be ready to release GK104 by April, but we are not aware of any solid date at this time. Jensen did mention that Nvidia had some lower than expected 28nm yields but also clarified that it is nothing like the transition to 40nm a few years back.
Despite some rumors that Kepler might be a good performer, AMD is still enjoying quite good sales of its 28nm products. It is getting ready to finish launching top to bottom portfolio from entry level all the way to high-end.
50-60%. What have you been smoking? Or are you ralking about some very specific benchmarks where the 7900's are overclocked to the max and 580 is not?When you can get 60% higher performance from a 7970 or 50% higher performance from a 7950, both, how many 580gtx's are being sold now and at what profit.
Just looked back a few pages and havent seen this posted yet,
http://fudzilla.com/home/item/26069-kepler-gk104-cards-in-production
eyefinity resolutions the 580 tanks badly and are way behind up to 80%.
^^ I think that's a 1.5gb 580. If it were a 3gb version the differences would quickly go back to the usual 20-30%.
No they wouldnt. The gtx580 they are using shows no signs of running out of memory. The real time frame graphs show steady fps on the gtx580 not erractic and extremely low minimums. Overclocked the gtx580 is no match for a 7970 oc. A gtx580 3gb might be a few percent faster but not enough to make these results look any better for the nv card.
If you're only playing at up to 1080p is there any real need for a better card than a GTX560 Ti or an HD6950 ?
It's drunkmaster, the master of pulling bull **** from thin air.
No problems.
Rroff, do you think Nvidia can bring more performance in @1080p or do you think they will get stronger after 1080p like the 79**'s?
