DBT, how do you know all these things? I see you answering everyones questions every day![]()
Just got my vitaCant wait to play it
I've been reading pretty much everything about the Vita since it was first unveiled as the NGP. As a result I know lots about it and can make a nice OP with lots of information for folks that are only just finding out it even exists
Thanks for the info DBT.
As long as the memory card will still work in the later vita that's the main thing. Guy in store indicated that it would only ever work in 1 vita.
I'm hoping since I will only be using one PSN account the whole time, if i start uncharted tonight onto the card make saves, once I have deregistered the wifi vita and registered the 3g version it onto the account the card should just hop accross... worse case I lose saves.
All in all, it is a weird situation. All I wanted was a standalone 3G model without carts, but the local store I am trading my 3DS in for only had wifi version with carts in stock, so.....
- I bought wifi + uncharted for 230 quid.
- Later in the week when they get 3g version in I will trade in my wifi and uncharted for 245 quid at same store (yes, 245, it is not a typo), and get 3g version + uncharted (v2)
- Then I will trade in uncharted (v2) for PSN vouchers and buy downloadable version of uncharted (v3)
It does mean this week I will own 2 vitas and 3 versions of uncharted... which is why the weird questions![]()
Well put it this way, if it will only ever work in one vita there are going to be some unhappy people soon as they buy used cards. I posted my 8GB this morning so we should either see a puddle of rage posting in here tomorrow or a happy camper. I'mm 99.9% sure it'll be the latter.
Just make sure you do a backup of the card before you send the WiFi back, that way even if it won't work in the 3G without a format you still have your data.
I'll see if I can find out about the Uncharted save thing for you.
Ive not seen the starter kit in the shops, only the travel kit. I assume they are both different?
Yes, the Travel kit has the car charger in and the start kit doesn't probably some other differences too.
EDIT: someone found an easter egg in Uncharted when on his second playthrough, this time on Crushing difficulty. Spoiler alert. Real actress is made jump by someone on set and every has a laugh, it's all rendered into the game with the character movements too.
http://www.youtube.com/watch?v=ZG6kcKNjFbw
