Looking to buy a TouchPad for Android fun, is the FB405UA the one to go for? Seems to be a small of £99 stock kicking around.
do what i did, do a full factory reset in CWM then clear both caches then re-flash alpha 2, then install gapps
Problem solved - ended up flashing a nightly build from the 28th then installing Gapps
Loving it!
I'm struggling here, I've managed to get moboot etc on there and I've installed CM9 as per the cyanogenmod wiki but when it starts up it gives me the boot options (clockworkmod/cyanogenmod/webos), CWM works, Webos works but CM9 starts, I get the initial splash screen then it reboots back to moboot.
Any ideas?
Hi, Can sombedy advice me on Android instalation.
Used my HP TP for 2 weeks and luck of aplication on WEBOS makes me want to install Android (love Android on Galaxy s2), just checked couple youtube videos and thinking to install this:
I believe it is latest version CM9 and installation looks quite easy!
Do I have to consider something before installing android? will I have chance to delete it if something goes wrong? or any other useful tips welcome.
Thank You.
when I connect device to PC my computer won't install usb drive.
