Any chance you can upload it to Mediafire or similar to share , as i have the same Mobo, using the F7n Bios with the same problem?.
I would also love it if you could do the above. Been in contact with gigabyte a few times they never got back to me.
And you're going over the thermal limit, only half an hour in.
Core Temps should never be looked at, they are ALWAYS wrong. CPUTIN is his actual temp, so he's 2C over recommended thermal limits. The CPU isn't going to explode, but its not healthy to run at that temp for long periods.
It only runs that hot on Prime95, doesn't go above 64c. Doesn't really bother as me no games/software stress it out that much and i'm not one of these hardcore overclocking nuts that nurses a semi while overclocking everything.
beside i'll have an X6 coming tomorrow anyway.
I highly doubt the CPUTIN is correct on there and he is best off looking at the core temperatures which are well within the limits. If it was hitting 64c the computer would shut down I would have thought, or at least make a warning beep, unless of course he has turned warnings and throttling/shutdown off.
64c isn't that hot, but it's past the AMD core limits.
Not that it'd bother me lol.
Why would you care about cpu lifespan ?? Even if it will die in 3 years how many of YOU had cpu over 2 years ??
I change them every year for something never. It is best way to go tbh. You sell what you have for some descent cash add another 80-100 and you got new one. And 4 year old cpu is worth **** ALL. So you need to spend like 200 on new one and you still had to use one cpu for over 4 years.
Its like my roommate hes got c2d he payd **** loads for 4.5 year ago. Now it cant run **** on it.... Only way is full upgrade for him.
Buchtis -I'm in Chaddesden if you need any advice / help - I have my 1055T @ 4ghz on all 6 cores
