No doubt it will work but you won't need to as you can plug your PSV into a PC anyway via USB.
(Or am I missing the point here?)
If you plug the Vita in to a PC while it is on it goes into data transfer mode and will not charge via USB. Once turned off it will.
The modification to the data pins on that USB adapter tells the Vita that it is connected to a power source and not a data source. As a result it will charge when on or off or in standby. With this mod, all I need with me is my USB cable and that adapter and I can get power anywhere with a USB port even while the Vita is on. As it is I carry my battery with me anyway.
On Monday/Tuesday a different adapter should arrive and I BELIEVE it might do what we need without any modification. Won't know until it turns up though so hold off on ordering anything.
Still need to get the other secret car for doing the Pitwall trophy then DBT?![]()
Yep
I imagine if you were to load the game up and set the best time possible on every track you'd never be able to get the pitwall trophy since nobody would be able to beat you in order for you to then beat them.
