They also revised the shader architecture, unlocked 32 additional sharders, and reduced transistor count from 3.2bn to 3bn.The 560ti 570 and 580 were hailed as excellent cards. All that Nvidia did, though, was fit them with low leakage transistors (to lower the power draw) as well as a TDP throttle to stop them using as much power when ran in something like Furmark, and a better cooler (a vapor chamber, oddly the same one that had used when they revised the too hot too loud 260 and 280).
The GTX480 significantly outperformed the 5870 at launch, and does so by an even wider margin now. Even AMD's revised 6970 only just about matched the GTX480's for performance.All of that smacks of fail. The fact that OCUK (almost two years on) has a huge batch of EVGA GTX 480s says it all.
I kind of agree here. £450 for a single GPU graphics card is horribly expensive, even for a card that was comfortably the fastest card of it's generation.At £450 they were horrifically over priced, so any one waiting for them with any sense just went 5870 as the 480 and 470 pretty much confirmed all of the rumour and speculation. They were too hot, too loud, too late and most importantly of all too expensive.
In truth, almost all of the problems NVidia suffered with Fermi can be put down to the very poor 40nm process. Perhaps they were also a little naive producing such a large die, but the GTX580 proved that the basic architecture was sound. Hell, the 580 almost competes with AMD's top 28nm part, and the 580 was really what the 480 should have been from the very start (barring process hiccups).
The 480 was and still is a very good card. I had no regrets upgrading from a 5870 to one, and then onto a 580. Infact, my 480 was not that much noisier or hotter than my 5870 or GTX580, and few people who have owned 480's have had bad words to say about them. They may not be within the 9700Pro or 8800GTX class for performance, but they are closer than the current 7900 series will be given respective generations.
Sorry, but I have very fond memories of my GTX480. In performance terms it was just as good / better thab the GTX580 gieven the half-generation gap.
