BT Infinity & FTTx Discussion
What's the current router of choice for FTTC? Asus RT-N56U? Cisco linksys E4200?
Edit: I've gone with the Asus.
FTTC Output Power Levels v Sync Speed
Hi All,
I have recently noticed from my HG612 modem's GUI that my DS Output Power levels fluctuate a little, quite often between GUI screen refreshes, so I have graphed power levels to get a visual idea of what it looks like.
The first graph is from a 18Mb Sync speed FTTC connection.
The second graph is from my 30Mb Sync speed FTTC connection
The third graph is from a 40Mb Sync speed connection
Just concentrating on DS Output Power levels for now, the difference in pure visual appearance is clear.
My own connection has been rather unstable over the last 7 months or so, eventually having a DLM reset 10th March, which initially provided a 35Mb sync speed for the first time since July 2011.
I first thought that stability had also improved, but following a number of "on the fly" resyncs at lower speeds, it is back down to 30Mb Sync speed, with Attainable rates around 33Mb to 36Mb, depending upon the time of day.
The 18Mb connection is stable, but around 1600m from the cabinet.
The 40Mb connection is also stable & around 500m from the cabinet.
My own 30Mb connection does not appear quite so stable & the 4 day graph above shows fluctuations in DS Output Power levels, whereas the other 2 connections show very steady Output Power levels.
I also notice the differences in DS Output Power levels for all 3 connections is not massive, despite the large differences in sync speeds.
The whole range is only between 11 dBmV & 13.7 dBmV.
I have seen other Output Power graphs from other users with varying speed connections & they also look steady.
The Windows Ongoing data harvesting script already stores any changes to Output Power levels, but the released graphing scripts do not plot the graphs (yet).
If anyone on the 80/20 trial would like to send me a copy of their ongoing modem_stats.log, could you please contact me via PM for an email address, or if you already have my email address, could you please forward a copy to me?
Alternatively, could you please upload the log file somewhere & post a link to where I could download it?
I will provide the graphs by return email, or post them here.
Does anyone know if the Output Power levels come from the actual sync speeds, or are sync speeds dictated by Otput Power levels?
Does anyone know if fluctuating power levels are a symptom or a cause of an unstable connection, or is it a "normal" phenomenon?
Paul.
its the BT HH3 some say its great others say its bad , the Asus is a great router :)
a) not sure if I would want to stick with it for the extra cost
b) not sure if it's worth the hassle for the trial period (service may be up and down, I work from home sometimes)
c) GF may kill me.
a) it will revert back, and it runs until nearly the end of April now. A month of free double speed, why not.
b) it's a profile change, it will happen practically instantly in the middle of the night.
c) Mine likes watching the speedtest dial fly round to 65mbit ;)
Has anyone in a mixed fttc/p area got fttp yet?
Supposedly we're meant to be able to get infinity here by the end of march yet i've seen no sign of fttp even though a bunch of cabs have popped up for others around here, the bt checker isn't very helpful.
Loads of people around my area have fttp now and some have had it since Aug last year. Sadly my road still isn't available.
I watched FTTC be installed on my street (well the cab) and it took about 2 weeks before the availability checker on BT site was reporting that I could have infinity
Talk Talk website appears to be "working" now, although appears I can still only get the 40/12 profile ATM:
the 38.8 is pretty much spot on, but the 6.1 upload is slightly out:
Mines showing the following:
Great news. You can benefit from Superfast Fibre Optic Broadband.
Your Superfast Fibre Optic Broadband download speed will be 64.6 Meg with an upload speed of 20 Meg.
Compared to your current download speed of 10.3 Meg.
Enjoy groundbreaking speeds at great value. With our fastest broadband yet you can watch more, play more and share more.
Snap!
:D
Your estimated download speed would be 56.5Meg and upload speed would be 15.7Meg.^
Compared to your current download speed of 6.4 Meg.
The 6.4meg is a little off, I get 8-9 at the moment, so hoping the 56.5 is a little higher, but the 15.7 sounds good to me!
Also "Superfast Fibre Optic Broadband is planned for your line in April 2012" so that's confirmation 80/20 goes live in April:D (not that the Openreach document wasn't already confirmation!).
I hope everyone who uses the TalkTalk estimator realises some muppet from Talktalk will phone you trying to earn his 50p in commission.
Just a heads up.
Mine is still showing as ready by 31-March-2012. Last time it did this was December when it showed December-11 until... 2 weeks to go when it moved to March.
What are my chances?
fox your not down in Hampshire are you my exchange goes live then but my line shall be installed before that, so its already live in some areas
Base it on the activity on your local area. ;)
Anyone else having problems?
Tracing route to multiplay.co.uk [85.236.96.68]
over a maximum of 30 hops:
1 <1 ms <1 ms <1 ms 192.168.1.1
2 6 ms 6 ms 6 ms 217.32.142.5
3 6 ms 6 ms 6 ms 217.32.142.30
4 6 ms 6 ms 6 ms 213.120.163.14
5 6 ms 6 ms 6 ms 217.32.27.54
6 208 ms 213 ms 199 ms 217.32.27.182
7 189 ms 194 ms 203 ms acc2-10GigE-11-2-0.mr.21cn-ipp.bt.net [109.159.2
50.206]
8 220 ms 225 ms 232 ms 109.159.250.150
9 195 ms 246 ms 202 ms peer4te-0-3-1-0.telehouse.ukcore.bt.net [62.172.
102.25]
10 224 ms 223 ms 227 ms 194.74.65.58
11 233 ms 230 ms 239 ms te5-2.gs1.core.enta.net [87.127.236.42]
12 241 ms 217 ms 213 ms te1-1.interxion.core.enta.net [87.127.236.86]
13 198 ms 210 ms 206 ms gi4-3.enta-transit.as35028.net [84.45.252.122]
14 205 ms 208 ms 211 ms www.multiplay.co.uk [85.236.96.68]
Trace complete.
