***** The Official Galaxy Nexus Thread *****
got the phone.
they said they have found the issue and updated the software...
Now Im running on
I9250XWKK5_ITL41D
kernel 3.0.1-ge24633f2 android-build@apa28#1
android version 4.0.1
as I dont remember what I had earlier, can someone check ?:)
at same time...does o2 unlock phones for free ? the code I bought from ebay, works, but I need to type it in everytime I take SIM out which is not good...
got the phone.
Now Im running on
I9250XWKK5_ITL41D
I have:
I9250XXKK6
ICL53F
Android Version 4.0.2
Looks like they've flashed your phone with an older version of ICS?
got the phone.
Now Im running on
I9250XWKK5_ITL41D
my phone needs the unlock code each time i take the sim out
I have:
I9250XXKK6
ICL53F
Great....
Just got notification that system update is ready for download...will get it done once get home
As for simlock and typing code in everytime its not how it should be....
so system downloaded update, resets it self, than animation of updating starts and few sec later changes to android on his back and red exclamation mark...
and Ive noticed, that previously when phone was starting there was only Google(before whole animation)
now, there is google and on bottom of the screen there is small image of unlocked padlock ...anyone knows what that is ??
so at the moment, I have nexus with old software...and unable to install new as now it says system up to date...
You're sure this padlock wasn't there before? They've unlocked your bootloader, possibly to flash and older ROM onto the phone. Very odd. I would call them and ask why they did this and can they provide you something in writing that unlocking your bootloader has not voided your warranty...
got the phone.
Now Im running on
I9250XWKK5_ITL41D
Sounds to me as they have flashed a Samsung build (yakjuxw - ITL41D-I9250XWKK5) on your phone and returned it with an unlocked bootloader.
Download “Android System Info”, look at system and then buildinfos. This shows a normal “yakju” build from Google which you now appear not to have:
It will tell you whether you have this Samsung build.
If it is this build then it will probably explain why the update failed. You may then want to look here:
http://forum.xda-developers.com/showthread.php?t=1483273
Hope this helps. :)
Hope this helps. :)
will download this app now thanks
are there any advantages to have it unlocked ??
If you put ClockworkMod recovery on first, you can back the phone up as it is now, to restore later, than flash the new ROM.
I think you might actually be able to re-lock the bootloader, but it will wipe the phone.
i think phone is not rooted...clockworkmod recovery has problem with privileges ?
No, 'recovery', it's not an app. :) Do a little research on XDA, it's not the kind of thing you should walk in to blind. It's simple, but it's dangerous. As long as you can follow instructions you'll be fine.
I did a friends phone yesterday, unlock, flash recovery, flash ROM and kernel in maybe 10 minutes...
I know how to go in to recovery - volume down with power. but my phone is in odin mode than...not normal recovery...
ok.
rooting a side now...
my issue is still here!!! different firmware and it is still here :/
I may stop myself in downloading new roms ...
