thanks found it and is it worth getting?It's currently available for preorder from ocuk- stock arriving next week (see the op).
Well they have a 195W TDP, so say for example, the maximum the two of them would use is 390W, that would only leave you headroom of about 250W to power the rest of the system at full load.
from what i understand, nividias tdp is not the maximum wattage like most manufacturers - some research in this area is required![]()
650w will be fine. NVidia state a minimun of 550w so you room to play (overclock) with. Just 2x 6pins are needed so your psu is fine.Are these efficient enough yet to run two from a 650w power supply?
Away from home at the moment but have a Corsair TX650. Not sure how many 6 pin plugs it has but expect able to adapt 8 pin to 6 pin if the supply can handle two.
emmmmmm no lolmaybe when the evga classfied 2 comes around might do the evga stepup program
I see the price gouging is increasing![]()
"Price gouging...price gouging never changes...too many humans, not enough 680's to go around"
Hardly surprising when they can't keep them in stock for long enough - a stark difference from the 7xxx series from AMD. I'm actually surprised that we haven't seen the 7970 drop in price yet, as they should have done it before the release of the 680.I see the price gouging is increasing![]()
