- 3 Oct 2009
- Wales
Chest day = Sunday!!
Bring it!
It's all good i've got awesome calf doms from trekking round london all day yesterday. Feels niice
Bring it!
There's so much wrong with that workout I wouldn't know where to start. Good luck, you're going to need it...Had a good chest day today.
BB Flat Bench Press: 8x60kg, 8x65kg, 8x70kg;
BB close grip press: 8x50kg, 8x60kg, 8x60kg;
BB Decline Press: 8x50kg, 8x60kg, 8x60kg;
BB Incline Press: 8x40kg, 8x40kg, 8x40kg (felt really weak doing these);
DB Flys: 8x24kg, 8x28kg, 8x28kg;
DB Tricep Extension: 8x10kg, 8x12kg, 8x14kg;
DB Kickbacks: 8x4kg, 8x8kg, 8x8kg;
DB Bent over row: 8x14kg, 8x16kg, 8x20kg per arm (did these by mistake, oops).
BW Chest dips: 8x33kg assisted, 8x26kg assisted, 8x19kg assisted
Rope push down: 8x11kg, 8x13kg, 8x13kg;
15 mins interval CV, 1min@19km/h, 4mins@9km/h
Pressups - 12, 7, 5.
Looks like some of the weights went up this week, which I'm pleased about. Just annoyed I forgot to do my skullcrushers, but I was definitely spent after this session and I still have leg doms from yesterday!
Weighed myself today as well, I think I've creeped to 79kg now.
Kind regards,
David
...and you forgot the skullcrushers??!! Oh my![]()
Probably a stupidly nooby question but does that barbell count as weight on its own or is it purely the weights that you have added that you total up?
Nice and constructive! If you want to point out what you think is wrong with it it may help.
Go for it if you have the time to point out everything wrong with that..?Nice and constructive! If you want to point out what you think is wrong with it it may help.
Comments in greenHad a good chest day today.
No you did not
BB Flat Bench Press: 8x60kg, 8x65kg, 8x70kg; Your warmup is too much if 8x70kg is your working weight, non-productive
BB close grip press: 8x50kg, 8x60kg, 8x60kg; This is a tricep builder, why on earth would you pre-exhaust the smallest muscle group before all your planned chest exercises??
BB Decline Press: 8x50kg, 8x60kg, 8x60kg; why are you going up in weight? If you can lift 70kg for 8 reps on flat then what is the point of that first set of 8x50kg? You are more than warmed up by now
BB Incline Press: 8x40kg, 8x40kg, 8x40kg (felt really weak doing these);I'm not surprised! Even if you had a Ronnie Coleman chest (I'm guessing you don't) you don't need this much volume, cut it out!
DB Flys: 8x24kg, 8x28kg, 8x28kg; I take this weight is total and you aren't using 28kg DB's? Do you really need these?
DB Tricep Extension: 8x10kg, 8x12kg, 8x14kg; Again why are you raising the weights every set? You're way beyond warmed up here, hit the working weight
DB Kickbacks: 8x4kg, 8x8kg, 8x8kg; Sorry but there's no other way of saying this... You should be shot. What exactly are you planning to achieve doing Kickbacks with a 4kg DB? Please stop doing these before someone hits you with a barbell
DB Bent over row: 8x14kg, 8x16kg, 8x20kg per arm (did these by mistake, oops) No half measures here. Just to make 1000% sure you're over-training lets chuck in some random exericse for a completely different bodypart
BW Chest dips: 8x33kg assisted, 8x26kg assisted, 8x19kg assisted The daddy of upper body exercises and you do it 9th in your workout... after you're totally fried and you do it with an assisted weight almost 50% of your bodyweight? I'm lost for words......
Rope push down: 8x11kg, 8x13kg, 8x13kg; I'm sure your triceps needed a finisher? I guarantee you didn't use much tricep in this movement as they would have been shot to bits
15 mins interval CV, 1min@19km/h, 4mins@9km/h This is a workout all by itself, don't do this at the end of a gruelling workout, do it on it's own day... you're killing me here
Pressups - 12, 7, 5. Behave yourself
Looks like some of the weights went up this week, which I'm pleased about. Just annoyed I forgot to do my skullcrushers, (Sorry mate but this was the only good thing you did) but I was definitely spent after this session and I still have leg doms from yesterday! I'll bet you were, you wouldn't be keeping this up for long though
Kind regards,
David
I've give more advice on here than you've had hot dinners, those 11,000 posts weren't racked up in GD asking for advice on girlsThe whole point of this thread in it's own right is to somewhat help that person in why you find a problem with it...not just have a moan at them!
us gym rats have to stick together!
If I didn't know better I'd say that was a powerlifters routine with some flies thrown in.Speed squats
Speed deadlifts
Speed bench
Plate pinches
Reverse flies
Happy times![]()
Godly. There is a big difference between totally exhausting muscle groups and having a good workout.
Freefaller, what weight, reps, sets and rests did you use for your speed work?
Comments in green
Just to put this into perspective I've been training for over 20 years. I'm currently old and grumpy, 6' 1" approx 230lbs with a chest measurement approx 48" this is my current chest workout.
Incline DB Press - 3 sets of approx 12-6 reps
DB Flyes - 2-3 sets
That is it for a week!! I might do a single set of hammer machine chest press but I'll just pick a lightish weight and rep out, usually around 15 reps just to get some blood in there at the end of the workout and helps with the mind to muscle connection, afterall the pecs aren't a muscle we use that often. The trick is I make those sets count, they are all out, they are very intense and they hit the intended muslces with perfect form.
If I was trying to build some serious mass I'd drop the flyes and do Dips instead. I've got enough mass on my lower chest, I don't like the bottom heavy chest look so I'm just concentrating on upper chest. Seriously drop all that chaff you're doing and try this:
Dips - 3 sets
DB Flyes - 1 set
Close Grip Bench Press - 3 sets
Rope Pushdowns - 2 sets
Few Tips;
Don't do the dips assisted, use your full bodyweight even if you can only manage 3 or 4, you will rapidly gain strength (and size) with them.
As you get stronger on the Dips - Lean forward, bring your legs forward and flare your elbows. As you hit 12 reps, add weight by holding DB between your legs.
Stop one 1 rep short of failure on all exercises. Do not attempt a rep if you know you won't be able to complete it.
Powerful controlled lifts, pause, squeeze the muscle, slow controlled lowering of the weight.
On the flyes be sure to keep your arms bent at all times, at the top of the movement imagine there's a ball on your chest and you're wrapping your arms around it. Push the DB's together at the top very hard, you'll feel the pecs tense and burn.
Close-grip bench press means shoulder width grip. On an Oly bar than means just where the smooth part of the bar ends and the grip starts. Keep the elbows in to the sides. Keep the weight light at first and learn to focus all the weight onto triceps.
Perfect form, don't sacrifice it![]()
