Battlefield 3 thread - Server details in opening post -
Status
Not open for further replies.
Hit reg seems way off for me since this patch.
Particularly noticeable with the sniper rifles.
Scoped in on people and fire no hit registered whatsoever...
Anybody else noticing similiar???
The 8x and 12x scopes seem to have changed - certainly with an L96. Up to about 130/150m your bullet will hit above the crosshair, worse with the 8x than the 12x. Generally if you think you are scoped in on a specific range you will oveshoot on a headshot using DOPE from pre-patch (at least so it seems to me). Go shoot some walls at known ranges and see how it's changed for whatever rifle you were using - be useful to know if it's happened to all sniper rifles.
PKP + Foregrip + Holo + extended mag + SQD Suppress = trolololol you can't hit me rape times.
just had a few rounds on metro after someone showed me the insane suppressive power of this gun now. i was charging down the corridors between C and US deployment. all my team would be camped trying to push up, i would charge infront and just keep walking while unleashing the 200 round mag. .... i was getting streaks of 5+ easy... pushed all the way up from the corridor out onto C with my whole team following me. all the time i was being shot at... i believe samuel l jackson described it as divine intervention... i call it dice meddling with stuff :p
was pretty epic. give it ago :)
Getting the hang of the hit reg after the patch, although sniping is still dodgy.
http://battlelog.battlefield.com/bf3/#!/bf3/battlereport/show/27292573/1/235430453/
Best game of the evening. Had one on bazaar which was abysmal though and barely scraped by with a 1:1 KD ratio whilst my team got owned hard. Seem to have a stutter on bazaar which really affects aiming and people seem to warp around, plus the smoke effects on the game for me at the moment seem vastly different, which is very annoying.
Just tried it on the Type 88 LMG and the M60E4. I was being killed easily through suppression and I found it difficult to get a single kill. Ended up 10/11 and giving up. I used to be deadly with the LMG's now they are terrible and i've gone over the rpk and G3
Was getting no suppression assists either!, 3 people in my view point then WACK i'm dead
Yup, i was shot through solid walls, tbh im fed up with the cheating in this game.
Same as!
Was playing on Sienne and in one of the buildings, looked out the window and WACK dead one shot by a PKP. No suppression fire whatsoever, you could clearly hear and see that no rounds were being shot at my location previous to that.
On a softcore server!
FFS, Of all the things they could screw up, they had to screw around with sniping, it's almost completely broken now. :mad:
I have no clue where my bullets are falling because the bullet doesn't seem to change size as it gets futher from you - you simply see this giant circle covering your target. Also, the bullet speed and drop seems to be wildly different from before, which means unless the target is completely still, getting a hit is incredibly difficult even at medium range and thats just a torso shot, headshots are out of the question.
They've also broken the steady scope mechanism as the scope doesn't seem to want to steady half the time. Also when steadying the scope, it's not even completely steady anymore, there's still some drift.
Also, the Magnum .44 seems to have become even more useless after this patch. Seriously, why? The vast majority of players are too retarded to even use that pistol because it actually requires you to aim unlike 99% of the junk in this game. :mad:
Worst thing though is that they've gone ahead and ****ed around with all this stuff (which only affects a small majority of players) whilst bolstering everything in this game that promotes the 'run and gun, spray and pray' style of gameplay, which probably already represents 90% of the playerbase.
I'm usually getting around 3:1 K/D ratios in games, but after this patch I'm barely making 1:1. During this week I've had what I can safely say are the worst five games of BF3 since it's release.
Words fail me ...
I normally don't rage whilst playing a game as I think it's a silly thing to do. I mean, it's just a game at the end of the day, right?
That's all changed since this patch. I'm probably going to uninstall the game untill it's fixed or I forget about it altogether, as I seriously fear for the wellbeing of my monitor right now.
Yep, good times. Shots counted, G3A3 assualt rifle on recon, 3 shots at very long range, kill. M416 in bf3, full mag at point blank range, i get killed. Ive stopped knifing in bf3, it's too unreliable the reg is that bad. Far better with 30 rounds to the head at point blank range.
Status
