You crack on encouraging people to make systems unstable and if anybody disagrees, you report them as a Troll....
You crack on brother.
Well I tried getting into caspian border 64 player server again. This time I was also keeping an eye on system ram usage.
Again while game was loading, I got the yellow low memory error followed by the above BF3 error message, while systme ram has only been used upto 2.61GB out of 4GB total
Before starting BF3, the system memory usage (idle usage) was around 1.45-1.5GB usage
If the game is using more than the VRAM on your graphics card you should turn the video settings down, paging is never ideal, particularly from VRAM because it is a major performance hurt. OK an SSD will reduce the effect of paging but it will still exist.Greg. What we are demonstrating here basically mimics that ^
IE - if you run an app that runs out of resources and it tries to use the paging file and finds it isn't there it will crash.
In other words - we are demonstrating that BF3 will use it when you run out of vram. Meaning, you are using more than your GPU has. Meaning, if it does so with a 1gb GPU then it obviously needs more than 1gb.
The end result? it IS caching from your paging file. Which WILL hurt performance.
Sure, the game will still run on a 1gb card. It will just be utter pants. See also this -
This thread demonstrates how Gibbo managed to come up with those results. Quite clearly because the 1gb card is using the paging file, and it is hurting performance.
Explain how even with a Pagefile active the same Low System Memory error occurs and adding 4GB of memory more fixes the problem then?
Why are you convinced it is VRAM when you are totally unqualified to make such a statement?
In short = This is another straw in the very large clutch of them AlxAndy has at poo-pooing the 680.
It's hardly rocket science...resolution(A)+quality settings(B)=VRAM usage(C). If C is too high reduce A and/or B.
Effectively the game will use as much VRAM as its video settings dictate, so if the VRAM is being paged out or the game crashes because of VRAM limits (in the case of paging disabled) the settings are too high.
Dont complain about a games demands at higher settings then?I agree completely. Hands up who is happy to turn things down.
Because I'm not. That's mostly why I game on a PC.
You spout all these observations yet are adament a GTX295 cannot run BF3 at anythning other than unplayable FPS even on the lowest settings.
Yet I did fine at 1920x1200 medium/low on a 285. For 90+ hours of game play, in my own system, with FPS/VRAM/GPU usage graphs and logging visible 100% of the time on a secondary monitor.
Perhaps all that illustrates is your inability to correctly configure a system?
	I must be the most unlucky person on the internet. Every time I get into an argument it turns out the person I am arguing with is a cage fighter !
So going by your logic, disabling the page file with for e.g. 12GB of ram will still bring up the error?Then as I continue to say - let's see it for ourselves.
Disable paging file with tons of ram and see if you get the error !
It's quite simple really !
I think I am gravitating more towards ALXAndy.
Before today (pagefile enabled), whilst playing BF3, my system ram would only go upto 3.3GB something. So I was still under 4GB limit.
Today with pagefile disabled, game crashed before I could actually even play and main ram usage was only upto 2.61GB as I posted already.
Well this is what I have experienced anyway in my case. May be different for other people.
Imo this thread has clarified the issue of BF3 paging from HDD as opposed to main memory, the latter which I believed in aswell previously.
