What kind of case are you after?
Have just received one of these today, ~£350 in all which I don't think is too bad. Based on the firmware though I think it is a HK device.
Pretty impressed, an upgrade from an Advent Vega so liking the screen a lot.
Can anyone recommend a decent case?
The major difference between the Honeycomb and the Ice Cream Sandwich version of the Android OS is the performance boost. Everything moves and feels fluid on the ICS, there are no glitches or performance bottlenecks as it was on the Honeycomb. Here is the Tab 2 10.1 in action.
AFAIK - His sim should work no problem.
Yeah I saw one yday for about that price and it was from HK, ******* was the retailer, anyone know anything about *******, the reviewers on site were v complimentary about price and delivery, as they would be.
Only had a brief go today but so far I'm really liking it!!
If your finding the stock launcher a bit laggy - use Go Launcher HD for tablets![]()
There is a good thread on AV Forums about the 7.7 and a lot of peeps on there got it from ******* - all very satisfied from what I read! (not sure if I can post a link to another forum??)
Personally I paid the £50 extra and went for the UK version from the rainforest!
This or the new ipad ?
Currently got a playbook which is giving me problems !! So deciding to change it !
What will you be using it for? The new iPad is unquestionably superior overall.
Both are massively better than the Playbook.![]()
Browsing, youtube and maybe some games and apps
Can't really argue against the iPad then, I'd definitely go for that.
I'd tell you to try both but the 7.7 doesn't seem to be anywhere and I'd say it's quite unlikely that you'd prefer it.
