Nice to see I'm not the only person hoarding the FW900's.
3 in use here and 2 working spares at the moment. And a couple of broken ones for spare parts.
Do you have them set up in Eyfinity/Surround or separate?
Im sorry but you are just completely nuts
I admire you for the dedication if nothing else, but yur still completely crazy![]()
*Nothing that advanced. Just an extended desktop as it's my work machine and as such games aren't installed *officially...*
They are amazingly good monitors though, been using them for years now. Until someone comes up with a LCD/LED screen that trumps these, then they will not be going anywhere.
Down to the nitty gritty; if you run a single GPU, yes; a single 16x speed PCI-E 2.0 slot will be fine. When you start to run multiple GPU's and/or run these new cards at 8x speed, especially in Surround/Eyefinity, make sure to get PCI-E 3.0.![]()
Do you think this would apply to 7970's in crossfire ?
Interesting results.
You're obviously at the extreme end of the spectrum running 4 GTX 680's.
The vast majority of users running multiple GPU's will be using no more than 2 so the question for them would be if that sort of difference exists in that scenario.
Perhaps you could take out 2 cards and run the same tests again.
Do you get the same results with the PCI-E slots set to 2.0 via the BIOS rather than this registry hack thing?
Hitting VRAM limit and PCI-E 2.0 vs 3.0 battle video tests. Make sure to watch in 480P instead of lower (I forgot to set the camera back to 720P and I don't feel like recording everything all over again lol). Sorry about the video quality but it is still view-able.
The PCIe 2.0 bit rate is specified at 5GT/s, but with the 20 percent performance overhead of the 8b/10b encoding scheme, the delivered bandwidth is actually 4Gbps. PCIe 3.0 removes the requirement for 8b/10b encoding and uses a more efficient 128b/130b encoding scheme instead.
