4x EVGA GTX 680's inbound.
shame about the lack of Vram for your use
4gb Vram is on the horizon apparently, would be worth waiting for at that res
How much!!!
This forum needs a crying smiley added.....and it should also be green to represent sheer jealousy![]()
Just curious vega but do you have an insanely good job or did you win your money?![]()
(going by your skills im guessing job but you never know)
Absolute madness but I love it! Vega what do you do for a living if you don't mind me asking? I've also seen your YouTube channel, why don't you post some build log videos?
Just a decent job, military pilot.
I bet I'm still a better helicopter in bf3
I bet I'm still a better helicopter pilot in bf3
Well, I found out that in nVidia's infinite wisdom they replaced the dual DVI-I slots found on GTX 580's with a single DVI-I and one DVI-D so each GTX 680 can only output to one analog monitor.
So I need a minimum of three 680's to run my setup which is normally fine, but I only have two 680's at the moment (two others inbound) but only a Z68 MB that can do two card SLI. So I have 680's and I basically cannot use them until Z77 comes out or I just use one monitor. I am tossing around the idea of getting a 3-way SLI capable Z68 from Amazon for temp use and just return it when the Gigabyte G1.Sniper 3 Z77 launches.
I had 3GB 580 benchmarks done and everything. Blasted! Right now 680's are making good paper weights.Maybe I will load up some games on my FW900's at 2560x1600 and crank everything to max and do some benchmarks/memory testing until I get the Surround monitor setup to 680's sorted.
Go for the Asus X79 and 3930k.. You will be sure to have a very solid multi card setup then, the 4 16x slots on the Asrock will do nothing for you apart from trouble.. :S I think anyway, on the very first z68 extreme4 the PLX PEX8608 chip gave me problems with multi 5850's.. Well that's what I put the blame on as my X59 board didn't have the same faults.. just like the NF200 chip did on the extreme 7 it would run fine on a single screen but not on Eyefinity..
