I would say it will last longer. Just like quads have been a better investment over dual cores CPU's. Just takes longer for the software to catch up.
that comment shows you know very little about what I'm talking about. The tegra3 will never surpass the Snapdragon S4 - EVER.
There's nothing that makes use of 4xA9 cores better than 2xKrait cores. The difference between A9 and Krait is relatively massive (much bigger than krait vs A15).
And the Adreno 225 is substantially more power than Geforce ULP.
Then we have the much bigger memory bandwidth and more superior Video encoder.
To top it off its 45nm vs 28nm.
You just cannot compare current Gen to next Gen ARM processor/SoC - much different to Intels incremental yearly updates.
While I may not be anal like you about phone technology I certainly know about multi threaded programming.
I'm talking from a programming point of view. While I may not be anal like you about phone technology I certainly know about multi threaded programming.
I noticed dropbox wont upload any photos etc if the battery is low.
Your point earlier was that Tegra 3 would last the test of time better than the S4?
Which is totally wrong. End of story.
There's no anal-ness here, just facts - and facts cut through BS.
Touchy.... It's just a phone to me mate.
I've no problem with that - making uneducated comments however...
I don't think the IPC improvement from A9 to Krait is as big as we have seen. Linpack and like are showing massive improvements bordering 100% gains. We stopped using such benchmarks on PCs a long time ago as they are notoriously unreliable.
225 substantially better than Geforce ULP? It's better I agree but for gpu accelerated UI both are adequate. So depends on how much weight you want to give that aspect.
Why is Krait's MPE better? I'd bet Tegra 3 can push higher bitrate video in a non hardware accelerated mode. Should be easy to test actually.
The PC processor market has a lot of history and the way the chips work is ultimately very similar and current desktop computing is what mobiles are gradually reaching towards. The performance questions are similar and software development will be similar (well actually I'd have thought it'll have a head start on smartphones).
Wouldnt using apples to apples as a test, and not different size screens, resoultion, and benchmarks designed with certain CPU/GPU in mind show more educated results?
Sorry missed your post completely.
Better GPU for better 3D games.
Better video encoder for better Videocamera performance - the compression on the One X is horrid - so it the stutters and shakiness.
There's just no way Tegra 3 is better than the S4.
you can use some stickers, like these, or the tags that come with the xperia and using an app, program them to make certain actions happen. You can also use it to send files, and read information from NFC enabled items, for example, you can read NFC ID cards such as those provided by my uni.
That looks good, how do i program the tags? For example to add one in the car to switch to blackbox software and mute calls?
There are a few apps which can do this.
