I should be getting my replacement laptop by friday, hopefully with a working battery this time!
anyway I wanted to know has anyone used the amd overdrive feature on the laptop which overclocks the GPU?
Does it make a difference in graphics performance? is it safe to do?
thanks
thanks
. Also the memory is overclocked then if it is 1866mhz and depends if the laptop allows memory overclocking, some don't and i'm not even sure the Samsung allows memory overclocking and can't remember seeing such a setting in the BIOS but will recheck tomorrow. The CPU RAM limit is final though 16GB is the Max for the Samsung laptop because the CPU can only access 16GB.
