- 19 Dec 2010
- Staffordshire
Are the red lines standard with Sport spec?
Yes they are.
You forgot rear tintsRecession white. Check.
Diesel. Check.
Big wheels. Check.
No leather. Check.
Lacking the best options. Check.
GJ.
Why got out of your way to explicitly put down somebody's new car?
I'm not suggesting you shouldn't have an objective opinion, but outwardly just putting it down without any other input....?
Nope too costly an upgrade tbh, as with Xenons. Budgeted myself £1000 for upgrades, I'd have gone for 19s over nav tbh, I mostly know where I'm headed and plenty of options on my phone when I get lost.
The Pro Nav is £2k and for that you get a wider screen, the Nav software, BMW assist and an upgraded iDrive dial.Does the upgraded Nav not incorporate other upgrades as well though? I was under the impression with the old models it pretty much upgraded the entire entertainment system too, is that not the case with the F30?
Diesel. Check.
Big wheels. Check.
No leather. Check.
GJ.
[TW]Fox;21646532 said:F30 is a much more premium looking car than the E90.
