Does adaptive vsync work in skyrim ?
First tests with new driver on Heaven benchmark. Strange the Max fps goes down but score goes up...
Do I install this driver right over the launch drivers? Or do I have to do uninstall the older one first?
AO and FXAA seem to be "Not supported for this application" for BF3. Any ideas? This is with 301.10.
To get driver fxaa in battlefield 3 you need to use nvidia inspector, just go to your bf3 profile in nv inspector and change the fxaa settings their, seen as the game already has its own fxaa built in the driver doesnt let you turn it on however inspector does, imo the driver fxaa is a lot better than the built in fxaa that bf3 uses the one in game is very blurry.
So if you have this FXAA turned on in the Nvidia control panel, should you have AA turned off in actual games graphics options?
Sorry if it's a silly question!
100% yes
When using adaptive vsync the frame rate needs to be at your monitor refresh or above so if it's 60hz/60fps vsync will stay on but if the frame rate drops below that it'll go off. Because you set to 59fps it's causing it to tear![]()
Was using 301.10 and listening to music on news grounds the screen went a garbled purple with masses of pixelated streaks down the screen, I could move the mouse through the pixelated mess. The screen then flicked and I saw " nvidia display has stopped responding and recovered " when it came back, So i'm trying these drivers.
Hopeing it's not a sign of memory failure on the graphics card, will keep an eye on that!
TXAA has to be implemented by game developers, and yes, it is exclusive to the 600 series.
The first game with it should be The Secret World, followed by Borderlands 2. In the long-term, Unreal Engine 4 will include TXAA as part of its dev kit, so expect to see its use grow massively in the coming years.
