In a post earlier in the thread
http://forums.overclockers.co.uk/showpost.php?p=21593223&postcount=983
I said that the Trustmaster T500 RS didn't work properly with Race '07 and it's expansions.
Well after a bit of digging I found Trustmaster have created a profile you can add to your SimBin/RACE07/UserData/ControlSet folder and I have to say it's absolutely superb. It makes the G27 feel like a toy iin comparison.
I have turned down the FFB settings in game from max to medium and slightly turned down other effects because they were just too strong. I also changed the wheel rotation from 1080 to 360 degrees in the Thrustmaster Control Panel, so the wheel movement in my hands matches the wheel movement on screen.
I was a bit miffed that Race '07 didn't work out of the box with my new wheel, but after adding the profiles Thrustmaster provide, it's added a new level to an already great game.
The profiles are on this page with instructions:
http://ts.thrustmaster.com/eng/index.php?pg=view_files&gid=1&fid=2&pid=316&cid=12
Might dig out my rFactor key now.
thats great info mate, im still thinking of buying a t500 and recently got into Race 07 and the btcc track mods, so i need it to work with the t500 if i get 1...
