Battlefield 3 thread - Server details in opening post -
Status
Not open for further replies.
anyone experience input lag/choppy FPS with MSAA enabled? im getting 60-90 fps with 6950 xfire but it feels like <30 fps and horrible delayed response to input, its like playing with vsync enabled
Not this tired ol one again guys.......lololol
+1....
To make Afterburner work with the mod you need to create a profile for BF3 in afterburner OSD. Then go to
C:\Program Files (x86)\MSI Afterburner\Bundle\OSDServer\Profiles
Edit the BF3.exe.cfg and replace the 'hooking' section with this:
Code:
[Hooking]
EnableHooking=1
EnableFloatingInjectionAddress=1
EnableDynamicOffsetDetection=1
HookLoadLibrary=0
HookDirectDraw=0
HookDirect3D8=1
HookDirect3D9=1
HookDXGI=1
HookOpenGL=1
Save exit etc and voilà!
Thanks to CK88.......Copy, Pasta and Spaghetti
Ah yes, I tried this one but it wouldnt let me save the edited file in notepad :confused: so i gave up and uninstalled the injector.
No... too long winded
Download
http://downloads.guru3d.com/MSI-Afterburner-2.2.0-Beta-15-download-2884.html
Make sure your osd is actually turned on via the monitoring settings
Load up the OSD, click the PLUS sign and direct it to the bf3 exe
Click the spanner top right hand corner and make sure the second box from the top is ticked ( enable compatibility with modified Direct3D runtime libraries ). Also make sure the OSD for BF3 is actually enabled don't need it globally!
That's it
I'll give it a try using that but is it worth it instead of the Nvidia driver level FXAA now?
I tell you what:
1. Report every one here who uses this "hack" on BL and see what happens
2. Install this add on http://getbblog.com/ and add everyone that uses this "hack" to your radar list so you can avoid us "pros" :p :D
3. Or you can simply install it yourself so then you are on a "level playing field"
My k/d, score etc. is no different to what it was before I used this injector, the only difference is that the game is more enjoyable to play as it actually has some form of colour rather than a dull grey blue tainted look everywhere and thus my eyes no longer get strained as badly when I was on the game for a hour or 2.
It appears that you are the only person who thinks it is a hack, PB and DICE themselves have said they won't ban anyone for using it (and if any action does happen, it will just be a kick until it is removed).
See thats what the fan of performance enhancing drugs say in mixed martial arts too.
Dont support the small guy who does it all naturally and on his own. Force him to juice up and roid with the rest of them by legalising PEDS. its not the right attitude is it?
Define for me what a hack is. You'll find the fxaa injector fits the description quite nicely. You already know its a hack, your just enjoying it because you can, for now.
What did you mean by level the playing field?i thought this mod made no difference and just increase frames per second by using FXAA instead of MSAA.
When one person tells me one thing and then someone comes on and says something completely different that contradict the first, one of you might as well just admit it, yes it adds FXAA, and it also makes it easier to see things on the map, including opponents by utilisng optimisations to the colour palette..
As i said if its just FXAA your after, well you can all remove the hack and simply use the latest geforce drivers (if you have the nvidia card ) right..?
Oh give over FFS it's not a hack. Your bodybuilding contest is of no comparison, because performance enhancing drugs are banned. The injector isn't.
It's a matter of personal preference same as with the colourblind settings
Has any one made use of the shortcut packs, the only one I would go for is the co-op just for the simple reason I'm never likely to do those missions.
I would not go for any of the others as i like working my way up through the various kits myself.
The Co-op stuff really doesn't take that much gametime to unlock. You'd be better off playing it for an evening with someone from here and getting most of the stuff.
Dude, you need to let this drop. Punkbuster who control what is and is not a hack say its not a hack. There is no further debate. Who do we belive, ballistix or punkbuster? I got with the anti cheat protection myself over some dude from a computer forum. No offence. :)
I have notice I've been getting a lot of lag with the game since the patch but my ping is between 15-30.
Yep, servers used to be buttery smooth, even with a 45-70 ping for me, but now even if I have 30 I get lag.
Can someone explain what the FXAA injector is? I'm thoroughly confused, although I have to say, using the colourblind settings makes reading things so much easier to read, despite me not being colourblind. I always modded the localisation of 2142 to give me orange/blue text instead of white, so I'm glad there's an option in BF3.
It isn't the colours, the colourblind has drop shadow, the regular has a glow.. don't get why they can't add that drop shadow to everything or make it an option though :(
Increased sharpness, increased gamma, increased saturation = way easier to spot the enemy in all situations.
Bah, shouldn't surprise me though. Back in the day in DoD and CS I remember certain clans who played at 800x600 with gamma so high there wasn't a shadow in sight :D
Not notice the ", it is to to sum up what you are saying essentially..... :rolleyes:
I am not just using this for the performance, the main reason I use it, is for this:
Plus a 4850 is not a nvidia card........
Keep telling yourself it is a hack, you are the only person that I have seen who thinks it is......PB and DICE have no problems with it and therefore it will shall remain in that same status for the foreseeable future unless the main developer/creator of it actually adds a proper "hack" to it.
Heck they have a lot bigger problems regarding cheats and the amount of people using actual cheats etc. to deal with first that are truly game breaking i.e the mass hack kill, you honestly think they will care more about a "hack" that simply adjusts the colours etc. to make the game more pleasurable to look at, which can still be achieved by simply adjusting your monitors settings?
And if it is a hack then why hasn't my k/d etc. shot up completely rather than being the same as what it was before I started using the injector?
Oh and;
At comparing this to "performance enhancing drugs for the human body" you crack me up! :D
Also I play with everything on low and turned off, therefore I must be "hacking" since I have a big advantage against other people who play on high/ultra settings since I can see people through bushes etc. more clearly than what others would with high/ultra settings......better report me for that......
Will just have to leave it at this tbh, as you are never going to change your opinion despite being the only person to think the same as what you do regarding this "hack" :D
Status
