BT Infinity & FTTx Discussion
Sounds good Spenty so what are the settings your using ?
These:
300Mb/s is FTTP.
If the track is half-decent, it will set the private & DHT flags to disabled. The user shouldn't have to do anything.
What private site do you use? I've always wondered, any invites? :D
Its set to private, but rules say you must disable DHT, so I guess they haven't forced that.
That's because no one needs anything from you, that will disappear if you get a peer downloading off you.
Oh great stuff ! must say its a lot faster downloading than utorrent ...so your right it is a great torrent software :)
Deluge is more aggressive, without any settings. On my seedbox deluge will give out 60MB/s-90MB/s, uTorrent I rarely see above 15MB/s even on TPB.
yeah i noticed the aggresive speed of the torrents straight away ! what seedbox do you use if i may ask ?
You can disable LSD in the settings of Deluge too. All it does is look for local peers on your own network, which I highly doubt someone on your own home network is seeding the torrent you want :p
thanks i,ve disabled that too :) must say i don,t think i,ve downloaded as fast in ages :)
Applied for the free upgrade tonight when someone linked me it, am I likely to get full speeds with the stats below?
# xdslcmd info --stats
xdslcmd: ADSL driver and PHY status
Status: Showtime
Retrain Reason: 0
Max: Upstream rate = 35342 Kbps, Downstream rate = 98244 Kbps
Path: 0, Upstream rate = 10000 Kbps, Downstream rate = 39998 Kbps
Link Power State: L0
Mode: VDSL2 Annex B
VDSL2 Profile: Profile 17a
TPS-TC: PTM Mode
Trellis: U:ON /D:ON
Line Status: No Defect
Training Status: Showtime
Down Up
SNR (dB): 22.6 30.8
Attn(dB): 0.0 0.0
Pwr(dBm): 12.5 1.3
Status: Showtime
Retrain Reason: 0
Mode: VDSL2 Annex B
TPS-TC: PTM Mode
Trellis: U:ON /D:ON
Down Up
SNR (dB): 22.6 30.8
Attn(dB): 0.0 0.0
Pwr(dBm): 12.5 1.3
Your before stats are better than mine were 37mb/8mb, so you should be good for even better than me after upgrade!
