So i got a new monitor last week, cost me £251 delivered with import duty, nice looking monitor, tempered glass screen.
However, it switched on ok, power was ok, backlight came on, but no bios screen, no windows desktop.
Looked like it was switching on when it should ,but no display.
Thought it may be my graphics card, or the dvi-d cable, heard lots of stories of dodgy cables, so i ordered 2 new ones, more sturdy.
Also went for a new graphics card amd hd 7850, incase it was my gtx 560.
Still the same, no bios or display, the monitor would show up if i connected another screen, windows was detecting it ok.
Emailed the seller, wanted me to ship it back to South Korea, would cost £70 , but he said he would refund me if faulty.
In the end, i thought, sod it, il open it up, see if a cable is loose.
These monitors are not meant to be opened up again , glass front (funny this, heard stories, hear a lot of stories on the internet of the glass dropping off, poor tape) haha, yes righto, this was the strongest tape known to man holding this chuffer on, the glass needs to be removed to get to the screws that hold the monitor in place, was going ok, then the glass broke, not that tempered, my temper was gone mind
Then i get to where the cables are, and i saw it straight away, a ribbon cable, was half in/half out, popped it back in , fired it up and bingo!!! it works.
If these things are put into place good at the start they dont pop out, they should lock in.
Heres the pics! and a video.
How it was
How it is now
It works!!
how it was before!
