Cheers Robbo, also another noob question, seeing this new One X is just a straight upgrade from Vodafone, I am able to put my current sim from my N1 into the One X right?
If you are getting an upgrade the microsim will be sent with the phone.
Mine's going back to P4U tomorrow for a straight swap. I swear the flickering problem is getting worse.
For anyone who wants to check if they've got it, make sure you're on auto brightness or full brightness, go to the battery use screen daz has screenshotted above and press on the graph. This will open out into a full page graph of mainly grey. On my screen said grey is strobing like an old CRT.
Had my HTC One X for a week now and last three days I've been having delayed texts and lots of people telling me they can't call and it's going straight to answering machine. It's a sim-free phone and I have a sim-only plan with T-Mobile. My message centre number and apns are all as they should be and I can call out, or use data, just fine.
After a bit of experimentation I've found that the texts and calls come through fine if I go into 'Network Mode' and select 'GSM Only'. If I switch it to 'WCDMA' or 'GSM/WCDMA auto' the problems return. Anyone else experiencing similar issues? Is this a problem with the new micro-sim, a network issue or the phone's radio?
Naturally, Carphonewarehouse, whom I bought the phone are telling me to call T-Mobile and T-Mobile are suggesting it's the phone. Any ideas, please?
Edit: Apart from the sms/call issues the phone itself is the best phone I've had, or played with. Battery life is a bit ropey but I expected as much with a big screen and quad core.
There seem to be a lot of software issues with this phone... Bit worrying as I was starting to think that Android was getting to the point it doesn't need to be flashed to use!
Did you receive a new phone and did it sort the issue out?
I can see a slight flicker / shimmer on mine. The wife can't see it.
However slightly concerned that if I send it back I might get something back with worse issues.
Well just convinced my girlfriend to go with the HTC one X. her Desire HD broke 2 months before contract finished. she got this deal with tmobile:
£70 for the phone.
300mins
unlimited txt
750mb internet
£26pm
It generally works fine, and any issues are down to HTC Sense more than Android. The Galaxy Nexus for example has very few (if any) issues.
Anyway.... Does Sense/ICS collate appointments from all sources into your calendar for display on the lock screen? I assume Outlook comes as standard, how about windows live and Facebook? Also can you get contacts (phone etc) from windows live and Facebook, and can you link contacts together and have just one with multiple sources (outlook, sim, Facebook etc)?
