I know this is a stress test. But I must say their servers are rubbish.
ok this is a shocker to say this but I have played D1, D2, every crawler there is out there, BG, NWN as well. And here is the bottom line. TITAN QUEST is better than D3.
WTF have Blizzard done. Runics Torchlight is seriously going to give this tosh a run for its money. PoE may do as well but its a little niche atm and needs more mass exposure.
still downloading!!! had to start it again this morning, anyone getting crazy spikes in the download speed?
would have been quicker to NZB it!
You on Virgin?
If you are, you'll find your 'superhub' router is actually restarting in those dips. They need to release a firmware to fix it apparently.![]()
Only did the very first little section to kill those "Queens" - but it felt very restricted in the map size. I assume you get bigger areas later on?
And what with the "loot Goblins" that they've shamelessly stolen from Golden Axe?![]()
slways fun to chase after them, especially when you're chasing one and they decide to charge through a big group of mobs and you've got to decide between survival and nice loot.
I've said it before and I'll say it again, I have no such issue and my hub has been rock solid for months.
My super hub has always been rock solid, apart from when running Blizzard updaters.Have you got the peer-to-peer download enabled? That slowed my download speeds right down as it was over hammering my upload![]()
Lucky you then.My super hub has always been rock solid, apart from when running Blizzard updaters.
It's a documented problem known to both Virgin and Blizzard, that many people have experienced with the superhub, and effects the WoW and SC2 updaters as well.
Same with the wow patcher.
It seems to prioritsie your UL over DL.
Go into launcher settings and disable P2P
Haven't been able to login yet![]()
I get in more or less straight away.
Have you set servers to the americas in options?
