Just had a quick look at the Tech Specs PDF and all I can find is RAID 0/1/10.Does anyone know if the SATA controller supports anything other than RAID 0 or 1?
It's the only thing putting me off right now.
I thought the N40L only had 2 RAM slots? The link you posted is for 4GB sticks - max 8GB? Not sure I've seen any compatable 8GB sticks.
Interested to hear from owners.
Jack
Sounds good.Think I'm going to buy one now, well in a minute!
Found a G7 for £280, so £230 after the rebate, ain't too shabby that!
I won't necessarily start my MCITP right away but mainly getting the server now to get the £50 which would almost cover the £60 for the 16GB RAM from OcUK.
N40L does have two RAM slots I seem to remember. What link do you mean? I haven't posted any myself.I thought the N40L only had 2 RAM slots? The link you posted is for 4GB sticks - max 8GB? Not sure I've seen any compatable 8GB sticks.
Jack
I just saw one that Ash2097 posted and seized upon the opportunity!I don't recall saying anything about 2GB apart from the G7 has 2GB pre-installed and I plan to replace it with 4 x 4GB sticks.The N40L does indeed have a max RAM capacity of 8gb, not 2gb. Maybe just a typo by Marc.![]()
Really? KB and mouse too? Well I shall find out tomorrow hopefully. I'm sure it has a DVD drive as there's nothing to say it doesn't whereas other ML110 servers on that site do have mentions of DVD drives needed. If it doesn't come with a DVD drive, I've either got one or I'll get one. The main reason I'm buying now is to get the £50 rebate.If thats where i got mine from it also comes with the CD-ROM. Keyboard & mouse where as others dont supply this, in particular the CD-ROM.
Cool. I might try that as well. Are you on MSN? I like to keep in contact with as many people using either this server or doing MCITP stuff so we can exchange advice and info.I posted off my claim form the other day but before doing so i emailed the claims/promo department to see if i could speed up the process by emailing them and thy said that was fine. Thought it might of been easier seeing i had been sent an invoice via email. All i had to do was provide my details along with the serial number of the machine.
Just a heads up.
But yes, I'm sure it was a typo.![]()
My original plan was to get the N40L as everyone else seemed to be but I realised that most people were getting the N40L as a home server to stream music. I wanted a server for MCITP/CCNA stuff so I was sure I needed something a bit more powerful. 2GB RAM limit on the N40L is just way too low, 16GB on the G7 is probably more than enough so I'll get a G7.![]()
Are you on MSN? I like to keep in contact with as many people using either this server or doing MCITP stuff so we can exchange advice and info.![]()
Ta. I've "fixed" it.Last sentence![]()
OK, might join up then.Not on MSN mate but i spend a lot on time on linkedin which is very good and has some great groups and some very helpful people.
Perhaps you can tell me via OcUK trust your contact details on Linkedin?
Cheers. I've joined up to LinkedIn but even with your self-description I can't find you!Done!
I got home later than usual today so I only had a quick look. I will unpack it more tomorrow and take some pics for both this thread and the Pics of what you bought in April thread in GD.
Doh!
Well my ML110 G7 did indeed come today. And you were right, Lorddalron, it does indeed come with a keyboard and mouse.I got home later than usual today so I only had a quick look. I will unpack it more tomorrow and take some pics for both this thread and the Pics of what you bought in April thread in GD.
I'll also try to email my claim form to HP like you did and save some time.![]()
