You're either running extra mods, which you have elected to install, or you have an issue with your your video card drivers.
You could try deleting your skyrim ini files in your Documents folder and running the launcher to re-create them.
Did they update this with some kind of texture patch ? I ran this on high when it first came out played it with no issues whatsoever. I stopped playing it in January and now when I start it up it just laggs like crazy.
They released the official HD DLC pack, could be thats a bit too much for your system, especially if you've got a card with low vram.
the hd pack is an optional download though
It doesn't download automatically. It's official DLC not a patch.
If you somehow have managed to install the High Res Pack just boot the launcher, select Data Files and disable it.
A 6870 is nearly twice as quick as a 5770 so you should see a nice jump in performance.
If you're buying the 6870 new, then I'd suggest saving a few more £££'s if you can and stretch your budget a 2gb card like the 7850 instead.
Skyrim's texture mods love extra vram.
It already does.i currently have mods like static mesh improvement, sky UI and better sorting. anyone know when sky UI will be released that supports skyrim 1.5?
