firstly, im very impressed with the monitor, the monitor itself is beautiful, the image quality is fantastic, colour replication also great. overall, very happy. though, im having some issues with the 3D side.
i've installed the 285.62 3d vision driver, with 296.10 video drivers, AW2310 EDID. when i turn on the 3d it works and performance is generally ok (q6600 @ 3.2, 6gb corsair dominator ram @ 800, HIS 550Ti..) frame rates are well within playable levels with 3d on..
after a weekend of testing i find the emulator work around solution is making my system very unstable. sometimes it will work happily for hours, but more often than not, my video card is shutting down after about 5-10 minutes of game play. even down to the cooling fan powering down to idle..
this is happening across the board of games and requires a restart to fix - turning 3d off doesn't correct it and windows performance is very sluggish when i exit out of the game. my GPU is reporting at < 62oC. windows gets stuck trying to shutdown a process fails to close preventing shutdown indefinitely.
if i don't use 3d, i dont have any of these issues, even with the emulator running. its only after turning on the 3d and playing for a short period does the system lock up.
i like the monitor a lot and don't want to go through the hassle of returning it, so if anyone can provide a better solution, it would be much appreciated.
, it has take a week. Good timing too as i'm about to order my new PC.
