The grey version is apparently quite slippy
especially compared to the black model.
I had a quick play with one in the shop but it was attached to the charging/security thing so couldn't properly "hold" it.
As for battery life, yup it is better than the X, however, it isn't just because it's "dual core", but more due to the new tech./gen of the CPU etc. so more power efficient etc. and yeah the screen is less power consuming unless you have white backgrounds on all the time
Check the last few pages of this thread to see about battery life comparisons.
Quad in theory should be better, but with the current tech./gen compared to the krait dual core in the S, it isn't.
Are you going to be getting a case? Cause if you are then the case mate tough sounds perfect for you, makes it a bit thicker and has a lot more "grip" to it than a "naked" S.
especially compared to the black model.I had a quick play with one in the shop but it was attached to the charging/security thing so couldn't properly "hold" it.
Check the last few pages of this thread to see about battery life comparisons.Quad in theory should be better, but with the current tech./gen compared to the krait dual core in the S, it isn't.
