Just make sure you delay getting married / children - they can reduce your disposable income greatly!![]()
but life gets better from that point on! Hence I'm re-building my pc for the first time in a long time!
Just to clarify, is it being suggested that the IB CPUs cannot be run at 100% CPU load for a long period of time (due to overheating)?
Can anyone outline the benefits of a Z77 board over the old P67 boards?
PCIE 3.0
Fully supported Lucid Virtu
Handles faster memory better (I think)
is there a list of software we shouldn't run ?
Or find someone like Mrs Bios!
I shall be hopeful... And work damn hard at that same time..
...as does divorce!but life gets better from that point on! Hence I'm re-building my pc for the first time in a long time!
I just try to laugh it off now adays... Or build shiny new computers since I love building/taking things apart
Apparently PCIE 3.0 is support on Z68/P67/H67 and H61
So the difference isn't worth changing for?
EDIT: watching that newegg video....my god americans use the term "go ahead" far far too much.
Old chipsets only supported a single PCI-e slot AFAIK
dual pci-e 3.0 @ 8x8x == dual pci-e 2.0 @ 16x16x
Lucid Vscoobydo or whatever it's called v2 which no one uses has been upgraded ehem 'fixed'
Direct USB3 pipeline to the CPU
More emphasis on mSata ?
Worth the upgrade ? Not really imho
p) I'm best off sticking where i am then. IB is worth less of an upgrade more of a new fresh build from a lot older chipsets so to speak.
Good to know, might just get the CPU upgrade and maybe treat myself to a second 27" monitor then
The reason being because it's a tock not a tick so to speak. Offers nothing really to someone who is already on SB since PCI 2 16x doesn't get saturated hell not even PCI 2 8x gets saturated fully yet either. Which makes PCI 3 just a little pointless for those already on SB. The lucid again not much of a big improvement. And the CPU themselves have 5-10% performance gaining over SB. Hence making a new build completely after having say a Q6600 its worth while. But going from SB to IB not so much.
I totally agree. But for those to whom Quick Sync is important this is a viable upgrade. 30+%
I'm taking it for that sole reason alone. Had it not been for that I would sit tight on my SB i7
I bought the barebones of my PC last night in a drunken whim kind of ordeal. Can't wait for them to get here.Nice. Sounds sensible.
BTW What cpus are you swapping out ?
i5 SB, I've wanted to upgrade to an i7 for a while now though. If i'd had a 2600/2700 i wouldn't be bothering.
Will be running it under a Noctua NH-D14 on an Asus P8P67.
Not sure if it will be decent upgrade. If you're maxing out your i5 then far enough.... if not then neck a few whiskeys like Ollie1132 and convince yourself that your upgrade is worth it![]()
