All of them have a gloss finish afaik.
Thanks
I can live with the gloss finish, but I need a height-adjustable stand.All of them have a gloss finish afaik.
I can live with the gloss finish, but I need a height-adjustable stand.ThanksI can live with the gloss finish, but I need a height-adjustable stand.
That's awesome! Thanks .Griff.
I'll have a look now for that model, but with a DisplayPort input. Otherwise it means I have to buy a DP --> dual-link DVI adapter for ~£70.
Don't forget most of these monitors have vesa mount holes. You can get a height adjustable stand delivered for about £30. I will probably get one for my catleap in a few weeks. The one i will get will probably be the allcam MMS01 with black glass base.
it really shows the "cheap" side of the monitor but now its out I love it. Hopefully I will get a reply tonight starting to miss the screen now. My brothers has arrived and he says it is working perfect. I knew I should have had it delivered here could have swapped them...![]()
The Yamakasi is a bugger to get the stand off though, trust me I did it today with mine![]()
Ah will be a breeze for you thenI was just shocked at one of the connections being held in place with electrical tape :S
Yeah the input lag bit's just important cos I play a lot of fighting games so anything under 16ms (input lag) is good for me.
Edit: Also does anyone know what the exact height (minimum height if it's got an adjustable stand) of the monitor is? Trying to figure out just how on a shelf it can sit before straining my eyes.
The dimensions are listed on the product descriptions.
Each seller has listed them for the model they are advertising.
