- 12 Oct 2010
- Stratford, London
Well unless the surface I place it on is made of diamond or sand it should be fine.....
Brick dust, tons of building material. Any road surface. It everywhere and it's very hard.Is there? what results in silica grit?
The RUU needs to match the CID of the phone though I believe or it won't flash.
Question about DropBox: it doesn't work as I expected, i.e. working as a service in the background syncing your DropBox folder like it does in a desktop OS. It seems to rely on Android app integration (i.e. 'send to Dropbox', share via 'Dropbox', 'open...from Dropbox').
So a weird question: can you give me examples of what you use Dropbox on your HOX for and why it is great?? At the moment all I see me using it for is automatic backup of photos (and videos) from the camera.
Think about what you're asking it to do here. Thank god it doesn't work like that, I have 47gig of space on DropBox. If it downloaded all that on to my phone, what do you think would happen?
So, some examples of why DropBox is awesome -
- I download a kernel from XDA, save it into my DropBox/Android/Kernels folder on my PC. Within seconds in the Android App I go to that folder and export it to my ROM folder. Boot into recovery and flash it.
- Because of the above, I can access almost all of my kernals and ROM's, not matter where I am, without having to make sure I keep them all on my phone.
- Photo sync means every photo I take is instantly (as good as) on my PC as a jpg.
- I have two or three shared folders, one for my family for example. My brother asks 'where do I get the Google Music apk from?' I stick it in the shared folder and he installs it direct through DropBox.
Those are the main points, the final big one is just all that cloud space so you don't have to carry all these files around with you, taking up space on your device.
Check the video guides below.
http://forum.xda-developers.com/showthread.php?t=1600957
I used the one below when I was getting mine ready to put a custom rom on.
http://forum.xda-developers.com/showthread.php?t=1592355
I know what I'd ask it to do: keep a folder specifically for this phone up to date, not the whole Dropbox! I think that's better functionality than manually drawing down files one at a time. I think I'm just annoyed that anything on my phone I want to keep I have to send it to Dropbox implicitly. I could already do that by emailing it to myself!.
No external branding of the phone but some software & their boot up screen is on it.
How do you change your launcher?
/andriodnoob
Finally picked up one of these the other day and very happy with it so far, it's my first Android phone.
Do have one problem though, when I get texts it only shows up the number and not the persons name on the home screen. My contacts folder and messages folder displays as normal. Annoying as I don't know who's text me at a glance.
