No those are older
301.34 is older than 301.25?![]()
doh I thought I saw .24 on the official website.
Max power limit is 125% ... what does that do?
On my windforce the max power limit is 111%. Seems my max oc is 1276(+100) core, 3260(+256) memory.
So the KFA2 is better?
I havnt found the max OCs yet, at stock settings the GPU runs at 1200 Mhz, +100 gives 1316 Mhz and is isnt stable, +85 gives 1300 Mhz and isnt stable, +50 gives 1255 Mhz which is stable.
So my max frequency will probably be around 1270 Mhz too, so much for the extra power power connectors and PCB.
Not tried overclocking the Vram yet.
Actually I'm having very poor luck with the GPU, even +50 isnt bench stable. But my ram is working problem free at +700 / 7400 Mhz![]()
I wonder why is the difference so big 125 v 111
Also does the boost in nvidia cards stop during gaming or its constant when load?
this is backing up what a lot of reviews are seeing, mid 1200's for the EX OC and windforce, even with all the apparent advantages they have
it fluctuates a little but is pretty constant when running a game/benchmark, unless you're in menus etc.
Thats good to know. Im still currently reading about this gpu boost and its doing my head in lol
Me also, I don't quite it how it works out the clock, I've noticed in less intensive game it goes quite low but surely it shouldn't do that because then I'm losing fps?
Is there anyway to keep the clock at a minimum? atm I don't feel my card even has a set clock, only a max clock which is strange.
It seems a fairly good indicator of the quality of the chip is how far the gpu will boost itself when at stock. Some will boost +220, others as low as +170. Mine will boost from 980 to 1176 when running heaven i.e. +196.
