- 16 Nov 2003
- On the pale blue dot
Is there a way to change the icons at the bottom of the screen with the menu button on it, and or is there a way to skin it as it really doesn't suit the way I want it to look. I know I can change the icons but I wish it was even a transparent bar.
You can drag them out of that bar and replace them with different apps if that's what you mean?
Check out the themes section of personalisation. I'm pretty sure one of the themes is at least semi-transparent.
