- 25 Apr 2011
- Crawley/Gatwick
managed to get 2203 but when i run gpu-z it says stopped working. I guess format will take place sometime soon
Does that score look ok for stock settings?
Try running the bench a second time, (once it completes hit f9 to run again) minimum fps seems a bit low. I remember a similair thing with heaven 2.5. Apart from that it looks ok.
Im using the latest afterburner, ver 2.2.1.
Settings im using below.
Power limit%, 111, (max)
Core, +130mhz
Memory, +750mhz
Fan left on default auto setting.
My highest so far, Gigabyte gtx 670 windforce.
1320mhz core (+130)
7406mhz memory (+750)
I havent touched the voltage slider at all. What sort of crash are you getting?Ok thanks, and core voltage set to 0?
Still crashing at the start?![]()
Yep, it's a nice improvement over my oc'd gtx 470's in sli. Not to mention a lot quieter/cooler. Ill be starting to save for another soon as well.haha thats doubled the score of my 6950 iceq. Cant wait to get hold of a couple of those windforce 670s
Setter, using your settings i get this when loading up the program. It gets very jittery and crashes....
I havent overclocked my cpu yet as im still running a stock cooler so maybe its this?
did you increase voltage? don't just enter someone else overclock settings, every card is different, you have to go step by step.
nice score, for an extra small boost go to nvidia control panel and put the slider from quality to performance if you haven't already![]()
