Happens to me on a 120hz monitor if that helps. It seems to happen more with games that have an engine based frame limit. For example fifa12 and Batman AC will both cap at 60fps regardless of v-sync setting.
From the current stutter list I have a conflicting experience. I've played Tribes: Ascend on my 680 and it did not have stutter.
Batman stuttered on all cards in dx11 mode, I had it on my 570. A recent patch fixed it though, so I'm guessing those reports of stuttering on ati cards are pre patch gregster, but would have to check the dates. That stuttering was a lot worse than the stuttering I've seen on these 670/680 cards.
Just had a look at the stuttering on youtube. I would be ****** if this was happening to me.
Also searching for a cure for Batman AC, it seems this issue affects 7970's also so maybe it is bad game coding? I read that turning off DX11 fixes it but this could be quite old and pre patch.
http://hardforum.com/showthread.php?t=1671095
Lazy game coders or lazy nvidia? regardless, no one who spends money on rigs and games should have to suffer the stutter.
I hate to say this but it happens on the Heaven benchmark to some degree too. I've been using it lately to work out my temperature issues with SLI 670's and I can see noticable stutters. When the fps are 100+ there shouldn't be any slow down what so ever, it should be smooth as silk. Yet I see the frequent pauses like the picture is sticking and catching up.
You have the reference EVGA 680 sin?
I did search a while back on changing the frame limit on fifa but didn't hit any results unfortunately.
Batman may be possible, afterall there is no frame limit in the benchmark.
