The 3770k I've now got my hands on is an absolutely pants clocker. No reason not to chop it off as its basically bin material currently anyway!
What kind of results are you getting Mike?
I'm doubtful they will release another stepping just to sort the heat there isn't really much of an issue tbh. After all Intel don't make us overclock its entirely our choice.
Ignore mate, I have faulty memory!
, hope you get some good results once you get sorted mate.just wondering about the liquid pro though.... think that it spilled over as he just put too much on or? that would be my only concern as like most cases the cpu is up on it's side... don't want it dripping about xD
Looks like he put way too much on. Just a little drop spreads very thinly over a CPU so over the die a much smaller drop should be applied and spread with a swab.
that's a nice drop in temps
although...can;t see to clearly from the pics but looks a bit odd with the liquid pro... i mean this stuff (form what i've seen) does the thinnest layer ever.. does it make good contact? (probably silly Q as you would have higher temps otherwise xD ) but it seems like the TIM does stick up a bit from the die? just looks a bit odd xD
also mx4... so did you use liquid pro on the inside and mx4 on the outside? i'm a bit confused xD
either way.... good job![]()
Yeah MX4 on outside as my heatsink is made from aluminium.
 so my question wasn't entirely silly
I wonder when the "thermally fixed" r2 Ivy Bridges will arrive? Surely Intel will do something about the heat issues and replace the crappy thermal interface material sooner rather than later.
Or maybe they made them this way deliberately to prevent high overclocks....
Also I decided to go on Intel live chat and spoke to technical support for cpu's (so as specific a choice as I could make), and the guy I spoke to said they weren't even aware the chips ran hot
I really doubt they'll do this, as the heat is not an issue at stock clocks for any of the chips, and of course overclocking is not 'normal' and is not covered by warranty etc.
Also I decided to go on Intel live chat and spoke to technical support for cpu's (so as specific a choice as I could make), and the guy I spoke to said they weren't even aware the chips ran hot and there was no plans to release different versions.
So either they just wouldn't reveal if they were going to bring out new versions, or from the first point they really don't care about/see as a problem the high temps.
Also, just as a bit of extra info for those that don't know, apparently the 24/7 max running temp of IVY is 75 degrees, and non 24/7 is 80-85. So at least it is perfectly safe to have some level of high temps.
 Apart from obvious physical damage i doubt they'd bother putting it under an electron microscope etc..Actually you're chip is still covered by intels warranty if you're overclocking. If the chip fails due to normal circumstances and you are with in the safe zone of voltage then it's not failed from you overvolting/running it too hot. Where as if you overvolt/chip degrades from heat over a long period of time and such this is when you need intels insurance.
