** EK Waterblocks RANGE FACELIFT - AVAILABLE TO PRE ORDER - ONLY AT OCUK **
  • Thread starter Thread starter rjk
  • Start date Start date
I never knew! :p (I did know some of that stuff was coming :p)
I really hope that you guys become one of the best watercooling sites in the uk :) (you're starting towards it!)
I want some nice koolance stuff, those waterblocks for graphics cards are full of awesome :D are you guys getting swiftech stuff in too?
Rjk - can we still buy GPU blocks with the real plexi on it? Or are EK manufacturing all GPU blocks only with rubbish plexi?
NEW RANGE LIVE ON THE WEBSITE TO PRE ORDER NOW
EK-Supremacy - CPU Waterblock - Copper Acetal @ £51.98 inc VAT
EK-Supremacy is a result of round clock development, years of experience and rigorous testing. As a new EK flagship this product again combines top hydraulic and thermal performance.
EK-Supremacy is a universal CPU water block that fits all modern CPU sockets with a universal mounting mechanism that offers error-preventing, tool-less installation. The result is a perfect installation which results in perfect performance every time. EK-Supremacy is truly the best product for performance seeking enthusiasts.
EK-Supremacy is a successor of the legendary EK-Supreme HF water block launched in 2010. It's main improvements are:
- better hydraulic performance: due to improved design up to 20% higher flow compared to EK-Supreme HF
- better cooling performance: up to 2°C lower CPU temperatures compared to EK-Supreme HF
The EK-Supremacy cooling engine uses similar, yet refined as per needs of modern microprocessors, fin design as its ancestor. The cooling liquid accelerates through jet plate's nozzle and turbulently continues its path through numerous very thin channels which provide extreme cooling surface area. Specifically designed and carefully machined copper base (sometimes referred to as ‘cold plate’) is made from purest copper available on the market and is further polished to absolute mirror finish. This alone greatly improves the cooling performance of EK-Supremacy.
EK-Supremacy is also the first CPU water block on the market which has been optimized for every modern CPU platform independently with the use of different type of jet plates to ensure the best contact with the CPU integrated heat spreader (IHS). These jet plates of different shape and thickness are enclosed with the product.
CPU socket compatibility:
- Intel LGA-1155/1156
- Intel LGA-1366
- Intel LGA 2011
- AMD Sockets: 939, 754, 940
- AMD Sockets: AM2, AM2+, AM3, AM3+
Enclosed in the box:
- EK-Supremacy series water block
- EK-CPU Precise Mount mounting mechanism
- EK-Supremacy Backplate system (Intel LGA-1366 & AMD AMx Backplate; Intel LGA-115x Backplate ; rubber gasket)
- Additional AMD Socket mounting plate
- TIM / thermal grease: Gelid GC-Extreme (EKWB 1.6g)
CAUTION:
- Legacy socket Intel LGA-775 is not supported by default – a EK-Backplate Supremacy LGA-775 is mandatory to install this water block on LGA-775 motherboards.
- Narrow server type LGA-2011 is not supported by default – a Mounting plate Supremacy LGA-2011 Narrow ILM is mandatory to install this water block on narrow server type LGA-2011 motherboards.
Only £51.98 inc VAT.
ORDER NOW
EK-Supremacy - CPU Waterblock - Copper Plexi @ £51.98 inc VAT
Plexi top variants have two slots for easy installation of 3mm LED diodes.
- Intel LGA-1366
- Intel LGA 2011
CAUTION:
ORDER NOW
EK-Supremacy - CPU Waterblock - Nickel Plexi @ £56.99 inc VAT
- Intel LGA-1366
- Intel LGA 2011
CAUTION:
Only £56.99 inc VAT.
ORDER NOW
EK-Supremacy - CPU Waterblock - Nickel Acetal @ £56.99 inc VAT
- Intel LGA-1366
- Intel LGA 2011
CAUTION:
ORDER NOW
EK-DDC X-TOP CSQ - Plexi @ £16.98 inc VAT
High performance aftermarket pump top for Laing DDC series water pumps. This top offer increased hydraulic performance (up to 15%) compared to factory top.
This top also featured two G1/4 threaded ports which allow installation of virtually any G1/4 thread fitting / barb. EK recommends EK-PSC series compression fittings.
Top is made of quality satin finish acrylic, retention screws and installation manual are enclosed.
Made in Slovenia - EU!
Only £16.98 inc VAT.
ORDER NOW
EK-DDC X-TOP CSQ - Acetal @ £15.98 inc VAT
Top is made of quality POM Acetal, retention screws and installation manual are enclosed.
Only £15.98 inc VAT.
ORDER NOW
EK-D5 X-TOP CSQ - Acetal @ £25.99 inc VAT
High performance aftermarket pump top for Laing D5 series water pumps. This top offer increased hydraulic performance (up to 20%) compared to factory top.
This top also featured three G1/4 threaded ports which allow installation of virtually any G1/4 thread fitting / barb. EK recommends EK-PSC series compression fittings. Additional outlet port allows easier tube routing possibilities.
Top is made of quality POM Acetal, mounting mechanism and easy to follow installation guide are enclosed.
Only £25.99 inc VAT.
ORDER NOW
EK-FC680 GTX CSQ Full Cover Waterblock - Copper Plexi @ £79.99 inc VAT
EK-FC680 GTX CSQ is a high performance full-cover water block for nVidia reference design GeForce GTX 680 series graphics cards. Please check our Cooling Configurator online compatibility system for detailed compatibility list!
This water block directly cools the GPU, RAM as well as VRM (voltage regulation module) as water flows directly over these critical areas thus allowing the graphics card and it's VRM to remain stable under high overclocks. EK-FC680 GTX CSQ water block also features a very high flow design therefore it can be easily used in liquid cooling systems using weaker water pumps.
Base is made of electrolytic copper while the top is made of quality cast, satin finished acrylic material. The sealing is performed by quality rubber washers. Screw-in brass standoffs are pre-installed and allow for safe, painless installation procedure. Block is mounted with enclosed M3x4 DIN7985 screws.
EKWB recommends the purchase of aesthetic retention backplate (EK-FC680 GTX CSQ Backplate - Black) which improves the looks of your graphics cards and also provide some passive cooling to the VRM section.
Any G1/4" threaded opening can be used as inlet or outlet.
Up to four EK-FC680 GTX CSQ series water block can be interconnected with EK-FC Bridge & Link system. The EK-FC Link is already enclosed.
Enclosed:
- EK-FC680 GTX CSQ series water block
- mounting mechanism with screw-in brass standoffs
- thermal pads
- link
Please note: Thermal paste is not included and needs to be purchased separately. EKWB recommends Gelid GC-Extreme for best performance. Torx T6 screwdriver needed for dissasembly of the factory heatsink/fan solution is also not included.
Made in Slovenia - Europe!
Only £79.99 inc VAT.
ORDER NOW
EK-FC680 GTX - CSQ Full Cover Waterblock - Copper Acetal @ £74.99 inc VAT
EK-FC680 GTX - Acetal CSQ is a high performance full-cover water block for nVidia reference design GeForce GTX 680 series graphics cards. Please check our Cooling Configurator online compatibility system for detailed compatibility list!
Base is made of electrolytic copper while the top is made of quality POM Acetal material. The sealing is performed by quality rubber washers. Screw-in brass standoffs are pre-installed and allow for safe, painless installation procedure. Block is mounted with enclosed M3x4 DIN7985 screws.
Enclosed:
- thermal pads
- link
Only £74.99 inc VAT.
ORDER NOW
EK-FC680 GTX - CSQ Full Cover Waterblock - Nickel Plexi @ £84.98 inc VAT
EK-FC680 GTX - Nickel CSQ is a high performance full-cover water block for nVidia reference design GeForce GTX 680 series graphics cards. Please check our Cooling Configurator online compatibility system for detailed compatibility list!
Base is made of nickel plated electrolytic copper while the top is made of quality cast, satin finish acrylic material. The sealing is performed by quality rubber washers. Screw-in brass standoffs are pre-installed and allow for safe, painless installation procedure. Block is mounted with enclosed M3x4 DIN7985 screws.
Enclosed:
- thermal pads
- link
Only £84.98 inc VAT.
ORDER NOW
EK-FC680 GTX - CSQ Full Cover Waterblock - Nickel Acetal @ £79.99 inc VAT
EK-FC680 GTX - Acetal + Nickel CSQ is a high performance full-cover water block for nVidia reference design GeForce GTX 680 series graphics cards. Please check our Cooling Configurator online compatibility system for detailed compatibility list!
Base is made of nickel plated electrolytic copper while the top is made of quality POM Acetal material. The sealing is performed by quality rubber washers. Screw-in brass standoffs are pre-installed and allow for safe, painless installation procedure. Block is mounted with enclosed M3x4 DIN7985 screws.
Enclosed:
- thermal pads
- link
ORDER NOW
EK-BAY SPIN Reservoir - Acetal @ £46.99 inc VAT
New EK-BAY SPIN Reservoir - Acetal CSQ is an updated reservoir by EKWB. Reservoir is made of quality POM Acetal material with fresh looking, satin finish acrylic top. The water flows over the flow indicator which shows the water is actually circlying in the system. Water flows afterwads to waterfall on front acrylic cover into the reservoir. On top of the reservoir resevoir caters G3/8 plug to easy fill/refill the reservoar with cooling liquid. Reservoir only needs to be put into an empty 5 1/4 slot. No boring or sawing is necessary. The reservoir is to be closed with enclosed plugs, thus a closed system arises. No water can evaporate from it which makes the annoying refilling unnecessary.
Features:
* Fits in DUAL 5.25" case bay
* Monitor your fluid level
* Monitor your flow with flow indicator
* Easy installation
Specifications:
* Includes: white flow indicator/impeler
* Main body size: 144x84x60 MM (LxHxD)
* Volume: ~ 250 mL
* Thread size: G1/4 "x 4
* Thread for filling: G3/8
* Material quality: POM Acetal, acrylic
* Color: Black (body), satin finish (cover)
* Includes (1) G3/8 plug
* Includes (2) G1/4 plug
* Includes (1) 8mm Allen key
* Includes: (4) M3 screws
Only £46.99 inc VAT.
ORDER NOW
The acetals don't look too bad, an improvement IMO, but why, just WHY would you make the plexi so you can't see through it easily?!
Hide flakey EN? :p doh lol yeah exactly wrexad :)
I agree though, nasty looking. The only reason to use plexi is because you can see through it, otherwise you may as well use acetal which is superior in most other ways.
something just occurred to me, the plexi are opaque, but the circles are clear, if you stick leds in it I am guessing that the circles will highlight....which might look OK actually.....
Hide flakey EN? :p
:D
FYI rjk and EK:
Or maybe so you cant see the nickel peeling off :)
Hide flakey EN?
All of the new products with Nickel coating are all EN Nickel plated.
There is no issue with the EN process as it is a much more expensive way of producing nickel plated copper.
I only thought I would mention it as both of your comments seems to insinuate that you haven't heard about this?
This new process means there is no way there could be a problem with it unless you use a very aggressive biocide or an unconventional coolant. It is much more expensive to produce than the older method but EK never increased their prices to retailers or end users when they did this.
Moreover, EK did an exemplary job of resolving all issues that arose as part of the old nickel plating problem [which was a very very small problem in the grand scheme of things].
The way they handled the problem in fact was superb for such a small company.
This new line of products shows that they still invest heavily into their own company and that customers still trust the EK brand. They have just moved to a new premises to meet the logistic demands being placed on their supply chain, this is far from being happy coincidence.
Facetious comments are not welcome on these forums, If you have something slanderous to say about a company then do it elsewhere.
Just to add, Gregor at EK has polished my EN blocks which I thought to have been corroded. the polishing and returning of the blocks to me has been done completely free of charge; I will not hesitate buying EK products (until they get that damned plexi sorted out!:p)
