Post your mobile phone desktop!
My One S. Not bad for a start. Think I'll add a widget to the left screen, not sure what though!
My icons on the lock screen could do with being changed, that would require rooting right? :p
Apex Launcher Pro with a mix of ADW.Elegant and Kxnt Glasklart icon packs.
Fancy Widgets with ICS Shadow skin for the clock, Real Weather skin for the urr weather and Simple battery skin for the urrr battery. :D
Power Controls for the power widget on the right screen.
Whos in the wallpaper?
Still miss the go calendar widget :(
Will have to root at some point and get back the pure black notification bar along with the stock ICS notification icons and a blue circle battery meter :p
S3:
Got all the essential widgets, especially bus and tube times. One of the main reasons why I don't miss my iPhone 4S atm.
Just using a live wallpaper atm but need a really good wallpaper! Something like Megan Fox in 720x1280 maybe that isn't all white in the background? :)
What are the travel widgets you are using?
S3 too :p
1st and 3rd screens are TVFavs widgets showing recent and upcoming TV shows.
Copying my layout as usual, I see! :mad:
:p
BTW you see the dock icons you're using, are they slightly different to the ones here, a thinner coloured bar IIRC?
If yes, fancy uploading them for me please? ¬_¬
:p
