I thought exactly the same when I was looking at it in shops, and every time I pick it up now (albeit a bit less because it's never on 100% brightness).
Surely it's not an HTC issue, it's an app developer issue?
At first I thought that as well, however, after the first update for my S by HTC, the 3 dot menu was then removed from the youtube app?
Wish HTC would do that as well!![]()
It's both imo.
ICS has been developed to not have any buttons, so apps optimised for ICS should have software menu buttons. But then how many ICS phones have no buttons and how much extra work is it to just do that?
And HTC should have done some surveys/decent user testing, because even the smallest amount of either of those would have told them that people want a menu button rather than a task switching button (whose function is duplicated by the long-home button anyway).
It's the same story as the HTC Desire HD which had a search hardware button. Didn't use it once in two years.
It's easy for HTC to sort out.
They need to add an option under 'Developer options' to switch the function of the multi-tasking button to that of a menu.
Job done, zero problems.
They won't do this though, because they're stupid.![]()
Yeah, exactly. It's a decision they made, it's not something they 'need to fix'. App developers are the ones that can/are/need to 'fix' it.
It's a massively unintelligent decision.
Don't know if this is an ICS/HOX issue, but my conversations in Whatsapp don't have any contact pictures. When I click on the contact and then view in address book they have their Facebook photo, as per dialler etc, but nothing in Whatsapp. Any ideas? Worked perfectly before.
Interestingly when I go to edit the contacts photo it lists the usual options (Facebook, Camera, Gallery, Google etc) but it also lists Whatsapp as an option, which is obviously blank.
Yeah I've got that and am rooted, but don't see anyway of getting out of the SD card to system (and then enabling write access).
Edit: Found it in Settings.
Edit 2: Worked perfectly, thanks![]()
