This thread is rather long! Apologies if my question has already been covered in the previous 6194 replies
So I’ve ordered BT Infinity for Business with 1 static IP. Sadly it’s not for my home as my exchange hasn’t been done let alone my cabinet, but it’s for somewhere else that I’m responsible for.
BT have emailed me:
- Network login name *******@hg52.btclick.com
- Network login password ********
- Static IP 217.41.15.***
- Subnet mask 255.255.255.254 (well duh!)
They’ll be sending a BT Business Hub 3 in the post before the engineer arrives for installation, and he’ll bring the modem with him. But obviously the minute the engineer leaves the BT Business Hub 3 will go in the bin
and I’ll be connecting the modem to our load-balancing router... and herein lies my question!
So the settings for my router, PPPoE with the supplied Network login name and Network login password I assume?
And is it DHCP (the exchange DHCP’ing me my static IP based on the Network login name and password I’m connecting with), or is it manually configured Static IP? If it’s manually configured Static, what’s the Gateway IP Address I should use? BT have only emailed me the Static IP and Subnet mask.
I’m assuming I should use DHCP (and the exchange will DHCP me my static IP based on the Network login name and password I’m connecting with), because for manually configured Static IP I’d need to know the Gateway IP and BT haven't included it in the emails (I'd guess that it'll be 217.41.15.1 though)... but BT aren't planning on me using my own router anyways!
tl;dr "Settings for using own router"
