- 22 Apr 2011
- Nottingham
snip
Holy ****!
snip
Quick question lads..
My battery hasn't been up to a good standard since getting my phone (release date), to give you an idea, it goes down atleast 2% from when I take my charger out to about an hour later..
This is without applications running (accept the odd background process), this can't be right? Any ideas? Faulty battery that came with the phone? Would ordering a new separate battery from Amazon sort it out, or is it likely to be the phone?
For what its worth mine immediately goes down to 99% after removing the charger cable and then 98% upon connecting to wi-fi / collecting email / updating stuff (always have the phone in airplane mode over night).
That said I'm sending my handset back tomorrow because of an iffy camera.
Anyone got any case recommendations? I've seen the gel type on eBay, had one on my 3GS and they were okay.
Surely that's just the photo you've taken, not the camera itself? Wouldn't the S2 be more or less the same?
betterbatterystats is free on xda.
Mine is currently on 80% after 10.5 hours,.
I think he is referring to the fact that the camera on the S3 is showing the jeans in prefect quality to make it look like a window?
Just got the phone, its on charge. I've set most stuff up, I'm looking for a widget like power controls that lets you switch wifi / bluetooth / gps on/off. Seems TW doesn't have a built in one or am I missing it ?
Slide down your notification bar![]()
ah yeah ! I forgot that!
can you tell I came from gingerbread![]()
