what did you expectsounds normal.
S2 has slooooooow charging - with extended batt takes 4 hours iirc.
I don't know really, it just seems really slow. It hasn't bothered me on the other phones.
Mines the same with poweramp if i do anything else at the same time that has sound the volume goes crazy and also all the sound distorts massively. I'm probably just going to go back to using the stock music player
The length of time it takes for this phone to charge is just outrageous.
Just use 2A tablet chargers if you want to speed it up. Battery will get warmer though.
2A x 5V = 10Whr
pretty sure that doesn't work - the power throughput is limited by software on the phone.
Ah ok. Will need a fast charge kernel then.
Which is odd, because I've been getting 27 hours and more.
maybe u dont have anything synced?
i have two gmail accounts auto synced plys facebook and twiter. depends on usage mate.
i also usually have my wifi and/or 3g connection on most of the time. 12 hours and its dead for me
It has little to do with sync and everything to do with screen time.
I know it being kept awake is bad, but it's hard to know if it is that with no mention of screen time.
Something is definitely wrong with his phone, with that sort of usage I'd get roughly 3 hours screen on time (with auto brightness).
mate i have mentioned my screen time and i have also posted loads of screenshots like the guy above me in previous pages in this thread.
