Are you already a ADSL24 FTTC customer upgrading from the standard 40/10?
Yes, some have gone live, it's just a manual process to upgrade the service so the provisioning guys are working the best they can to process several hundred of them. Each one takes a good 10 minutes to do as there are various tasks involved to modify, update the product, check usage, sort out billing etc, so it will be done as soon as possible.
I'm keeping everything crossed but trying not to get my hopes up.
This thread is rather long! Apologies if my question has already been covered in the previous 6194 replies.
So I’ve ordered BT Infinity for Business with 1 static IP. Sadly it’s not for my home as my exchange hasn’t been done let alone my cabinet, but it’s for somewhere else that I’m responsible for.
BT have emailed me:
- Network login name *******@hg52.btclick.com
- Network login password ********
- Static IP 217.41.15.***
- Subnet mask 255.255.255.254 (well duh!)
They’ll be sending a BT Business Hub 3 in the post before the engineer arrives for installation, and he’ll bring the modem with him. But obviously the minute the engineer leaves the BT Business Hub 3 will go in the binand I’ll be connecting the modem to our load-balancing router... and herein lies my question!
So the settings for my router, PPPoE with the supplied Network login name and Network login password I assume?
And is it DHCP (the exchange DHCP’ing me my static IP based on the Network login name and password I’m connecting with), or is it manually configured Static IP? If it’s manually configured Static, what’s the Gateway IP Address I should use? BT have only emailed me the Static IP and Subnet mask.
I’m assuming I should use DHCP (and the exchange will DHCP me my static IP based on the Network login name and password I’m connecting with), because for manually configured Static IP I’d need to know the Gateway IP and BT haven't included it in the emails (I'd guess that it'll be 217.41.15.1 though)... but BT aren't planning on me using my own router anyways!
tl;dr "Settings for using own router"
Do you have to cancel your DSL service before you can order Infinity?
so despite being on whichever broadband package costs the same as infinity 2, bt want an extra £13 a month from us? how does that work?
I have had infinity for about a year and am on the 40/10 setup. In my account overview it shows I should get up to 76Mbps down. Do I have to do anything to get the higher speed? I'm trying to explain on a bt chat window for assistance but the girl is asking me what lights are flashing on the modem!
80/20Well the package BT labelled as "BT Infinity Home Hub 3" came in today. Opened the box, and discovered... it was simply two ethernet cables.
Get them contacted so the BT person can bring one or they can send you another ... BUT!.... check first bill as you may be charged twice (£6.00 per delivery).
.You want Infinity 280/20
Yes but is this just a simple change they need to make or will it involve a new contract?
Yes as mentioned it will be a new 18month contract though it should only be a change at the Bt side of things rather than your end ie. a house visit.Yes but is this just a simple change they need to make or will it involve a new contract?
Also depends how long you are into your present contract as it might be worth waiting until it's finished. If you don't mind a new contract I'd say deffo go for itI have been reading about some problems with these upgrades on the bt forums just now so I'm not sure if it is worth doing or not. I currently get 36Mbps and the new estimate is 53.
