iPhone - there's an app for that.
New MBP - there's an adaptor for that.
I just saw a picture of the new Retina Macbook - I don't like the new magsafe power cable - I liked the slim-line L shaped one better![]()
That is a good thing though.
Apple are taking a pragmatic approach to pushing laptops forward. If you are whinging about not having various ports then you are missing the point. Are you happy that they have got rid of the superdrive? Plenty won't be.
Its a great machine that is massive overkill for 90% of the people who buy it. If you want all the ports, dvd drive etc, get another laptop. I would have been hugely disappointed if they had just bumped the speed and kept the superdrive.
So you like the fact a laptop you'd keep for 2/3 years doesn't have the ability to change the memory or the HD?
Every computer I've ever had, be it laptop or desktop, has had a HD and a memory change in the 3 year stints I keep the machines.
I'd prefer the retina display, same thickness, removed superdrive and bigger battery + heatsinks etc for a faster, longer lasting machine.
My point was that you can't please everyone. They can only make it that thin by putting the SSD and memory on the board. You wan't something slightly different to everyone else.
If it isn't any use to you then thats a shame but they have sacrificed certain things to give you more in other areas.
Where is the limit? What do they sacrifice next?
The Air should be thin and light, the Pro should be a powerhouse.
(I put money on the Retina Pro being slower clocked on the GPU and doesn't Turboboost as much as the normal 15")
So get the normal 15" and stop complaining...
Has the voice in Siri on iOS 6 beta gone abit fuzzy ?
It's defiantly different from Siri on my iPhone 4
Not when it's £25 for an adapter to get something as old as a NIC!
Not much use if he wants the Retina display.
Not when it's £25 for an adapter to get something as basic as a NIC!
So he has to make a choice then.
