Oil & Filter change today was I right messy affair, The bike has 2 oil pumps which lifts the oil back up into the frame, The dipstick is just behind the headstock nut just behind the bars & when the caps off you can see the oil being squirted back into the reservoir at the top of the frame.
Anyways there is a small bolt just below the radiator & just above the downpipes that you have to take out to get the oil from the top of the frame & of course this flys out at first but then goes to a dribble that covers the downpipes no matter how much rag you use. Once that mess is everywhere you then go half way up the right side of the engine to remove the oil filter cover which then leaks oil all down that side of the engine as well.
Lastly you take out the sump plug which is the easy part, Checked for chunks of metal but there was nowt but a bit of swarf on the magnet so all cleaned up & put back together. Then you have to put a litre of oil in & prime it then run it then check/run/check/run
Finally got it Bang on the line & then went for a well deserved spin.
Run out of things to do now so I best go crash it like Stuman so I have summit to do.
It was badly stone chipped before.
Sometimes end up slowing down only for a smoking A4 TDI to rocket past.
